- Audi
- Q7 4L & Q8 4M
- Q7 4L
- 01400 - Suspension Level Control
Hello, I have recently had a problem with my air suspension, I get three error codes, 1577.1400.2250. As soon as I start driving, the yellow light starts flashing. I have VCDS. Can someone help me how I can identify the problem?
In the meanwhile I have read out with VCDS:01577 - Turn-Off due to Over-Temp
001 - Upper Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 6
Fault Frequency: 1
Reset counter: 59
Mileage: 232898 km
Time Indication: 0
Date: 2020.01.20
Time: 08:12:59
Freeze Frame:
Error Code: 68
Freeze Frame:
Fault Priority: 2
Fault Frequency: 4
Reset counter: 63
Mileage: 232938 km
Time Indication: 0
Date: 2020.01.21
Time: 17:07:36
Freeze Frame:
Error Code: 66
02250 - Function Deactivation; Valve Duty Cycle
Freeze Frame:
Fault Priority: 6
Fault Frequency: 4
Reset counter: 63
Mileage: 232933 km
Time Indication: 0
Date: 2020.01.21
Time: 16:57:01
Freeze Frame:
Error Code: 46
Anyone some hints?
yofatim is online now Report Post
20 Antworten
Hallo.
Problems with „over temp“ is coming up cause your compressor is not working that effectiv —> dischargevalve get slightly broken—> temp raise over 130 degrees celcius.
Suspension level exceed —> one or more valves to hold min-pressure in the airspring are defect. —> valve duty cicle limit exceeds
Sorry for my rather bad english...
Hello, Thanks you for your feedback.
In order to solve the problem, should I replace the compressor?
Or is there a kind of repairkit I can buy to fix the compressor?
I add some pictures and logfiles from VCDS
Address 34: Level Control (4L0 910 553 C)
18:40:38 Group 001: General
11.23 V voltage (terminal 15)
11.95 V voltage (terminal 30)
0.0 km/h Vehicle Speed
Term 50 Off Status Terminal 50
18:40:38 Group 002
Door Closed doors
Lid close tailgate
4.95 V Level Sensor Right Supply Voltage
4.95 V Level Sensor Left Supply Voltage
18:40:38 Group 003
0.00 m/s*2 longitudinal fitting adjustment
0.00 m/s^2 transverse adjustment adjustment
Relay OFF compressor relay value range: Relay ON / Relay OFF
18:50:34
105.0 vehicle height front left
108.0 vehicle height front right
163.0 vehicle height rear left
145.0 Vehicle height rear right
7.0°C compressor temperature
0.00 bar pressure sensor
OFF Discharge solenoid valve
OFF pressure accumulator solenoid valve
OFF air spring valve front left
OFF air spring valve front right
OFF air spring valve rear left
OFF air spring valve rear right
18:52:23
104.0 vehicle height front left
0.048 A damper valve flow front left
0.048 A damper valve flow front right
0.048 A damper valve flow rear left
0.048 A damper valve current rear right
-221.38° steering angle sensor (G85)
0.0 damper speed front left
0.0 damper speed rear left
1.0 damper speed rear right
18:52:26
162.0 vehicle height rear left
-1.0 damper speed front left
-1.0 damper speed rear right
18:52:27
0.064 A damper valve flow front left
0.040 A damper valve flow rear left
0.040 A damper valve current rear right
0.0 damper speed rear right
Address 34: DTCs cleared
19:07:25 Group 023
7.81 bar Pressure
0.0 (no units)
1.0 (no units)
0.0 (no units)
19:07:25 Group 002
Door Closed doors
Lid close tailgate
19:07:25 Group 003
19:07:32 Group 024
672 Count
324 Count
1192 Count
832 Count
19:07:32 Group 002
Door Closed doors
Lid close tailgate
19:07:32 Group 003
19:07:38 Group 025
312 Count
984 Count
84 Count
2620 Count
19:07:38 Group 002
Door Closed doors
Lid close tailgate
19:07:38 Group 003
19:07:43 Group 026
ON
678 /min RPM
Term 15 On
No
19:07:43 Group 002
Door Closed doors
Lid close tailgate
19:07:43 Group 003
19:07:53 Group 028
0.00 V Voltage
13.18 V Voltage
ON
OFF
19:07:53 Group 002
Door Closed doors
Lid close tailgate
19:07:53 Group 003
19:08:16 Group 034
104.0 (no units)
147.0 (no units)
162.0 (no units)
110.0 (no units)
19:08:16 Group 002
Door Closed doors
Lid close tailgate
19:08:16 Group 003
19:08:26 Group 036
6.18 bar Pressure
6.18 bar Pressure
6.18 bar Pressure
6.18 bar Pressure
19:08:26 Group 002
Door Closed doors
Lid close tailgate
19:08:26 Group 003
19:08:34 Group 037
233 Error Code
233 Error Code
Trailer: No
19:08:34 Group 002
Door Closed doors
Lid close tailgate
19:08:34 Group 003
19:08:37 Group 037
233 Error Code
233 Error Code
Trailer: No
19:08:37 Group 002
Door Closed doors
Lid close tailgate
19:08:37 Group 003
First of all i would change the valves on the airsprings. As an VCDS-User you can depressure each airspring to proove it. maybe you can see it where the level of your car is too high. This the seriuos problem.
Sometimes an error „over temp“ is in case of the mileage „normal“. But it shows the compressor is running out of lifetime. Sooner or later. As far as the car levels correct and the error appears not that much it will be not really serious. You understand?
It seems to be the valve on the left rear airspring.
Yes, you can try it and overhaul the compressor.
https://rover.ebay.com/.../0?...
Picture 10 shows the dischargevalve...
The right valves...
Hello White-head666: when a valve is broken or defective, is there vizual sign? Leakage of oil, or other ?
because I think it wil be cheaper if I start with replacing the discharge valves? According to your link: https://rover.ebay.com/.../0?...
they cost 34,79 euros?
I found a movie on the inetrnet, this person have replaced the same? vaalvesn right?
https://youtu.be/gCI-b4F6BZE
Then you also mentioned above "It seems to be the valve on the left rear airspring.", can you please explain why you think that?
Some additional information, on the picture you can see that te car is quite heigh in the rear. Yesterday I tried to lower the suspension rear left , rear right, front left , front rear with VCDS, but is doesn't work.
@yofatim schrieb am 24. Januar 2020 um 14:50:32 Uhr:
No
@yofatim schrieb am 24. Januar 2020 um 14:56:02 Uhr:
https://youtu.be/gCI-b4F6BZEThen you also mentioned above "It seems to be the valve on the left rear airspring.", can you please explain why you think that?
Look on your posted VCDS-Picture no. 4. The value „rear left“ is to much. So i would change this first.
These are two different problems. The „serious“ Problem is the valve for pressure-hold on the airspring.
