Begrüßungslicht - Leuchtdauer verändern/erhöhen
...geht das irgendwie?
Irgendwo muss doch die Zeit definiert sein. Ich finde es nämlich etwas kurz. Ideal wäre es IMHO wenn es einfach an bleiben würde bis man einsteigt und losfährt.
hier mal meine Nettodaten des LMA:
B 00300000,0010,80,07,30,00,00,28,05,AA,FF,00,00,00,00,00,00,00
B 00300100,0010,5D,90,42,43,50,96,1C,23,11,64,0A,07,07,0D,0A,0D
B 00300200,0010,1E,32,08,0A,32,19,1E,10,40,30,14,3D,19,15,00,00
B 00300300,0010,3C,01,06,0C,64,AF,96,1E,40,0F,0A,32,0A,50,78,1B
B 00300400,0010,64,14,32,64,1E,0A,FF,0A,06,30,02,3C,96,02,0A,20
B 00300500,0010,3C,01,06,0C,64,AF,96,1E,40,0F,0A,32,0A,50,78,1B
B 00300600,0010,64,14,32,64,1E,0A,FF,0A,06,30,02,3C,96,02,0A,20
B 00300700,0010,08,05,10,08,08,03,73,16,60,82,3C,4E,01,05,23,28
B 00300800,0010,04,EA,2E,08,00,00,41,46,33,64,D4,2A,00,00,00,00
B 00300900,0010,C7,E2,64,00,C7,00,5A,00,C7,00,5A,00,E8,14,23,00
B 00301000,0010,C7,00,23,00,28,2D,50,6E,8C,1E,46,64,06,0F,6C,03
B 00301100,0010,64,38,30,32,28,05,50,30,36,64,64,2D,41,82,AA,43
B 00301200,0010,73,13,FD,13,FE,13,18,FD,18,FE,18,6C,A5,6D,3A,9C
B 00301300,0010,B0,AA,18,96,96,0A,13,61,72,42,61,C0,18,F8,00,32
B 00310000,0010,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00
B 00310100,0010,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00
B 00340000,0010,33,63,F0,3F,3F,6F,F0,3F,0A,10,40,14,01,20,00,00
B 00340100,0010,3F,6F,F3,3F,51,00,00,00,00,00,00,00,00,00,00,00
B 00340200,0010,56,47,30,33,99,07,11,EE,01,14,14,01,30,FA,00,00
B 00340300,0010,F1,05,35,00,64,00,00,00,00,00,00,00,00,00,00,00
B 00340400,0010,0C,92,08,C9,05,00,3C,0A,9E,00,00,00,00,00,66,00
B 00340500,0010,97,71,00,83,0A,00,51,00,14,53,01,01,59,04,00,00
B 00340600,0010,00,10,FF,1F,BB,0B,FF,1F,FF,1F,BB,0B,FF,1F,FF,1F
B 00340700,0010,65,0A,2C,0C,2D,0C,AF,09,D7,0A,2C,0C,FF,1F,00,10
B 00340800,0010,00,10,00,10,00,10,6D,4A,00,03,00,00,00,00,00,00
B 00340900,0010,65,0A,2D,0C,00,10,BB,0B,66,06,A5,24,21,68,2D,04
B 00340A00,0010,02,27,7F,D7,52,60,0A,0A,56,14,04,37,C0,88,88,88
B 00340B00,0010,88,71,5E,51,47,3F,36,2F,2F,2F,2F,2F,2F,2F,80,4B
B 00340C00,0010,00,00,8C,44,65,43,40,30,00,00,00,00,00,00,00,00
B 00340D00,0010,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00
B 00340E00,0010,61,56,07,10,00,C8,0C,05,14,55,00,04,00,00,00,00
B 00340F00,0010,42,50,07,10,00,C8,0C,05,14,55,00,F8,00,00,00,00
B 00341000,0010,49,0B,23,00,00,10,2D,08,00,00,FF,1F,05,0B,04,56
B 00341100,0010,3E,05,01,01,05,01,00,30,00,92,24,48,00,00,00,00
B 00341200,0010,F3,00,F0,00,05,04,0A,BB,1C,07,3F,1A,35,91,05,55
B 00341300,0010,81,8E,0B,65,0A,AF,09,00,00,00,00,00,00,00,00,00
B 00341400,0010,20,30,14,2A,C0,0C,32,BB,0B,FF,0B,FF,0B,FF,1F,81
B 00341500,0010,28,27,28,27,28,33,28,27,28,27,28,27,00,00,00,00
B 00341600,0010,00,07,00,07,00,07,00,07,00,07,00,07,00,00,00,00
B 00341700,0010,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00
B 00341800,0010,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00
Betreffend Welcomelightdauer ist folgende Zeile ausschlaggebend:
Gem NCS Dummy ist Wert 08 (gezählt wird Wert0, Wert1; Wert2, etc) für die Dauer verantwortlich => 14 (HEX) = 20 (DEZ)
D.h. du ändest die 14 in 3C und hast dann 60 Sekunden Welcomelight (3C HEX = 60 DEZ)
Danach die Nettodaten abspeichern, wieder aufs STG schreiben und Freude daran haben :-)
PS.: Der maximale Hex Wert ist FF,was 255 Sekunden entspricht aber ich denke das dürfte zuviel des Guten sein :-D
33 Antworten
Öhm ...wo genau?
Ich finde da nichts was meine Frage beantworten würde.
Meinst du damit die Heimleuchten, oder was ist mit Begrüßungslicht gemeint? Mit Heimleuchten ist die Aktivierung der Leuchten durch das Ziehen des Fernlichthebels gemeint.
BMW_verrückter
Original geschrieben von BigMäc
Öhm ...wo genau?
Doch... da steht, dass man das alles codieren kann. Notfalls mit einem speziellen Modul.
Nein ich mein schon das Begrüßungslicht oder Welcome-Light oder wie es auch immer heißen mag ...also die Standlichter, Rückleuchten, Kennzeichenleuchten und was da alles mit an geht wenn man das Auto mit der FB aufsperrt. Das geht an und nach ca. 20 Sek. wieder aus ...und diese Zeit möchte ich ändern oder eben "abschaffen" so daß alles an bleibt bis ich einsteige und losfahre.
@AndyB1971: Sorry, aber ich seh's nach wie vor nicht, in dem anderen Thread geht es darum ob man die Nebelscheinwerfer als Begrüßungslicht verwenden kann ...das will ich ja überhaupt nicht.
Und natürlich erhoffe ich mir auf die Frage keine Antwort á la "ja es geht" :-D
PS: Zusätzliche "Module" wie z. B. das E-Light o. ä. sind nicht gewünscht.
Hast du dafür schon eine Lösung gefunden ? oder Codier Parameter ?
WL_DAUER
wert_01
das ist bei mir eingetragen aber was ist oder wie hoch ist wert_02 ?
Eisen
Servus,
ich hab das schon Codieren lassen es ist auf jedenfall möglich. Mein Codierer allerdings hat das nicht mit den Normal methoden geschafft der musste das im HEX editor abändern sonst hat er den wert nicht übernommen. Aber er hat es geschafft ^^ 60 sek sind es jetzt und zusätzlich mit Neblern.
Original geschrieben von key_master80
Servus,
Ja er hat wahrscheinlich mit netto Daten gearbeitet. Wäre natürlich interessant eine Tabelle über die werte zu sehen. Hast du die Möglichkeit dein LMA auszulesen und hier zu posten?
Eisen
Servus,
Eisen
Nein im moment noch nicht, bin aber gerade da ran mir alles nötige dfür zu besorgen.
Super Danke,
ich werde mich sofort am Wochenende mal dran wagen
Eisen
Hat geklappt mit den Nettodaten Vielen Dank
Freut mich! Danke für die Rückmeldung und fürs Danke Button drücken :-)
