  4. Audi
  5. A3
  6. A3 8V
  7. ACC module asking SVM code (Retrofit)
Audi A3 8VA Sportback
Hi
I have retroffited na acc module in my a3 8v 2016
The problem is i can’t activate it since dealer ask for a svm code.
I don’t have any cloue how to get that code, they have removed the componente protection but ask for svm code to activate it.
In vcds i have this
10 Faults Found:
1807 - No Enable Indentifications Active (Activation needed)
B2032 00 [009] - -
[New feature! Extended UDS Fault Status: 00000001.
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 92
Mileage: 47602 km
Date: 2018.03.27
Time: 16:56:15
Control Module temperature: 31 ° C
Voltage terminal 15: 12.3 V
Vehicle speed: 0.00 m / s
Acceleration: 0.00 m / s²
0288 - Databus
U1121 00 [009] - Missing Message
[New feature! Interfaces]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 92
Mileage: 47602 km
Date: 2018.03.27
Time: 16: Extended UDS faulted is currently supported by current. 56:15
0310 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 92
Mileage: 47602 km
Date: 2018.03.27
0287 - Databus
[New feature! Extended UDS fault detail is only supported by current gen interfaces].
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 92
Mileage: 47602 km
Date: 27/03/2018
Time: 16 : 56: 15
1804 - Internal Fault
B200F F0 [009] - Unknown Error Elaboration
[New feature! Extended UDS fault detail is only supported by current gene interfaces].
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 92
Mileage: 47602 km
Date: 27/03/2018
Time: 16: 56: 15
1803 - Internal Fault
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 92
Mileage: 47602 km
Date: 27/03/2018
Time : 16:56:15
Voltage terminal 15:12.3 V
1802 - Internal Fault
B200F F0 [009] Unknown Error Elaboration
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 92
Mileage: 47602 km
Date: 27/03/2018
Time : 16:56:15
1801 - Internal Fault
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 92
Mileage: 47602 km
Date: 27/03/2018
Time: 16: 56: 15
1800 - Internal Fault
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 92
Mileage: 47602 km
Date: 27/03/2018
Time: 16: 56: 15
1792 - Sensor for Automatic Distance Regulation; Incorrectly Positioned
C1103 00 [009] - -
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 92
Mileage: 47602 km
Date: 03/27/2018
Time: 16:56:15
Any help?
Thanks
https://www.facebook.com/mqbretrofit/
They can do FEC in gateway.
01 – Engine
– for manual gearbox you need to tick ACC – PR-8T5
– for DSG gearbox you need to set ACC with Front Assist (PR-8T3, PR-8T8)
03 – ABS (coding for 29 bit) you ned to edit bit 24:
– for manual gearbox you need set: 14 (or 16)
– for manual gearbox and Lane Assist you need to set F4
– for DSG gearbox you need to set F8
09 – Gateway
– Add 13 – Auto Dist. Reg on the installation list
– Under Adaptation change steering wheel type to ACC
17 – Instrument
– On the cluster set all the ticks for Front Assist and Distance Regulation
5F – Radio
– Set all the ticks for Front Assist, ACC and PreCrash
A5 – Front Camera
– Set presence of ACC
The last module that need to be coded is the Radar itself. Here is my coding for the unit:
Address 13: Auto Dist. Reg (J428) Labels:| 5Q0-907-567.clb
Part No SW: 5Q0 907 567 P HW: 5Q0 907 567 P
Component: ACC3 H10 0100
Coding: 00000100FE030B
26 weitere Antworten
26 Antworten
If the tester recognizes other hardware on Audi than is stored on the server, the tester asks for an SVM code.
Thanks for this info but how can activate this?
Is there a way?
Thanks
Unlock component protection and coding is only possible via the Audi server.
Whether it is with VSDS I do not know now.
The component protection has been removed by Audi server, but after, to activate it ask that svm code and they say they don't know how to get it.
I'm stuck now
The audi-Dealer only has to remove the component-protection. The coding can be done via VCDS. But you need to know how. Since Audi doesn‘t offer the retrofit officialy, he won‘t be able to do the coding. But it is possible (I retrofitted the ACC also, But with help from a good VCDS-Coder). Have you changed the rear brake-sensors?
Yes i did.
Can you help me?
If you install a used sensor with a different part number you have the same probl.
You have to look for someone with VSDS that can encode the part.
You need a new Gateway because your Gateway has no FEC for ACC.
Yes i have xenon
I need a new gateway?? I put the installation list and i can communicate with the module so my gateway seems to be the right one, no?
Thanks
With xenon you have already the right highline-Gateway. So n worrys about that. But worry about the wrong sensor with the SWAP-Protection. Get yourself a 5Q0 907 541. The flat ones can´t be used for a retrofit, that is what I know from my researches.
The gateway does not have a FEC code for ACC.
That is where the
comes from.
So do worry about this.
There exist a procedure for adding ACC FEC to a gateway but it has to be brand new afaik.
Hello, so i tried made the same. Is there any solution ?
I have activated from Audi dealer Cruise Control, but ACC still not work.
Address 13: Auto Dist. Reg (J428) Labels:| 5Q0-907-572-V1.clb
Part No SW: 5Q0 907 572 D HW: 5Q0 907 572 A
Component: ACC Bosch MQB H03 0304
Serial number: 20061376510137
Coding: 000C1301FE033B
Shop #: WSC 66666 123 28888
ASAM Dataset: EV_ACCMRRBoschVW372 001015
ROD: EV_ACCMRRBoschVW372_VW26.rod
VCID: 383CDC6E83632B8A2D-806C
3 Faults Found:
1071 - Databus
U1123 00 [008] - Received Error Message
[FAULT_CIS_AXV_INVALID]
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 141
Mileage: 69339 km
Date: 2018.10.27
Time: 23:24:30
Control Module temperature: 31 °C
Voltage terminal 15: 11.9 V
Vehicle speed: 0.00 m/s
Acceleration: 0.00 m/s?
1058 - Databus
U1123 00 [009] - Received Error Message
[FAULT_CIS_ECD_NOTAVAILABLE]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 101
Mileage: 69339 km
Date: 2018.10.27
Time: 23:24:30
B2032 00 [009] - -
[FAULT_SWAP_NO_FSID_ACTIVE]
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 101
Mileage: 69339 km
Date: 2018.10.27
Time: 23:24:30
ok, you have deleted the component protect from your dealer?
But have you coded the rest of your car? And retrofited the the switch?
I think you have to code the "speedometer" "Gateway" "Engine" and not sure but "ABS"
