- Wissen
- Fahrzeugtechnik
- On-Board-Diagnose
- Audi einparkhilfe optische anzeige
Friday,25,April,2008,19:30:51:07360
VCDS Version: Beta 803.4
Data version: 20080413
Chassis Type:
Scan: 01 03 05 07 08 09 0E 15 16 17 19 37 42 46 47 4F 52 53 56 61
62 72 76 77
VIN: WAUZZZ4Fxxxxxxx Mileage: 41450km/25755miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
07-Control Head -- Status: Malfunction 0010
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
0E-Media Player 1 -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
37-Navigation -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
56-Radio -- Status: OK 0000
61-Battery Regul. -- Status: OK 0000
62-Door,Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
76-Park Assist -- Status: Sporadic communication error 1000
77-Telephone -- Status: OK 0000
Address 01: Engine (BDW) Labels: Redir Fail!
Part No SW: 4F0 910 552 R HW: 4F0 907 552 D
Component: 2.4l V6 MPI 0010
Revision: --H15--- Serial number:
Coding: 0105000318070018
Shop #: WSC 77836 146 00336
No fault code found.
Readiness: 0010 0001
Address 03: ABS Brakes Labels: 4F0-910-517.lbl
Part No SW: 4F0 910 517 D HW: 4F0 614 517
Component: ESP8 front H03 0010
Revision: 00000000 Serial number: 00000000000000
Coding: 0004433
Shop #: WSC 02325 785 00200
Address 05: Acc/Start Auth. Labels: 4F0-910-852.lbl
Part No SW: 4F0 910 852 HW: 4F0 905 852 B
Component: FBSAUDIC6 ELV H30 0220
Revision: 31050601 Serial number: 10600300047244
Coding: 0000001
Shop #: WSC 76287 146 16944
Part No: 4F0 910 131 D
Component: FBSAUDIC6 EZS H43 0070
Part No: 4F0 910 220 D
Component: FBSAUDIC6 IDG H35 0020
Address 07: Control Head Labels: 4F0-910-7xx-07-H.lbl
Part No SW: 4F0 910 729 Q HW: 4E0 035 729
Component: Interfacebox H43 0500
Revision: 00000000 Serial number: 350GV047527559
Coding: 0000001
Shop #: WSC 02335 785 00200
Part No: 4F0 910 609
Component: Bedienteil MMIC6H07 0870
2 Faults Found:
01043 - Control Module; Incorrect Software Version
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 5
Fault Frequency: 2
Reset counter: 228
Mileage: 41450 km
Time Indication: 0
Date: 2008.04.25
Time: 19:02:58
Freeze Frame:
Bin. Bits: 00000000
Bin. Bits: 00000100
Bin. Bits: 00000000
Bin. Bits: 00
01317 - Control Module in Instrument Cluster (J285)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 5
Fault Frequency: 12
Reset counter: 228
Mileage: 40106 km
Time Indication: 0
Date: 2008.03.03
Time: 11:51:45
Freeze Frame:
Bin. Bits: 10
Address 08: Auto HVAC Labels: 4F0-910-043.lbl
Part No SW: 4F0 910 043 HW: 4F1 820 043 G
Component: KLIMABETAETIGUNGH04 0100
Revision: 00000022 Serial number: 00000000043218
Coding: 0000006
Address 09: Cent. Elect. Labels: 4F0-910-279.lbl
Part No SW: 4F0 910 279 B HW: 4F0 907 279 B
Component: ILM Fahrer H14 0080
Revision: 00000000 Serial number: 4F0907279
Coding: 0000101
Part No: 4F1 910 113
Component: Wischer AudiC6 H05 0150
Coding: 00062736
Shop #: WSC 02335
Part No: 4E0 910 557
Component: REGENLICHTSENSORH10 0040
Coding: 00141886
Shop #: WSC 02335
Address 0E: Media Player 1 Labels: 4E0-910-111.lbl
Part No SW: 4E0 910 111 C HW: 4E0 035 111
Component: CD-Changer H44 0340
Revision: 00000000 Serial number: AUZ5ZBD4024134
Shop #: WSC 00000 000 00000
Address 15: Airbags Labels: 4F0-910-655.lbl
Part No SW: 4F0 910 655 D HW: 4F0 959 655 B
Component: 32 AIRBAG AUDI8RH28 0250
Revision: 04H28000 Serial number: 0037LD0391HV
Coding: 0013106
Address 16: Steering wheel Labels: 4F0-910-549.lbl
Part No SW: 4F0 910 549 HW: 4F0 953 549 A
Component: Lenksäulenmodul H07 0230
Revision: 00H07000 Serial number: 90026042020053
Coding: 0002011
Shop #: WSC 02323 785 00200
Part No: XXXXXXXXXXX
Component: Lenkradmodul H04 0080
Address 17: Instruments Labels: 4F0-910-xxx-17.lbl
Part No SW: 4F0 910 900 A HW: 4F0 920 900 M
Component: KOMBIINSTR. M73 H08 0630
Revision: 00200000 Serial number: 4HY32DN74
Coding: 0004043
Address 19: CAN Gateway Labels: 4F0-910-468.lbl
Part No SW: 4F0 910 468 A HW: 4F0 907 468 B
Component: Gateway H09 0030
Revision: 09 Serial number: 08008047190153
Coding: ECEE53C41B3104
1 Fault Found:
01327 - Control Module for Parking Aid (J446)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 226
Mileage: 41431 km
Time Indication: 0
Date: 2008.04.24
Time: 18:43:37
Address 37: Navigation Labels: 4E0-910-88x-37.lbl
Part No SW: 4E0 910 888 E HW: 4E0 919 887 C
Component: MNS ECE H43 1050
Revision: 00000000 Serial number: 353GT047543763
Address 42: Door Elect, Driver Labels: 4F0-910-793-42.lbl
Part No SW: 4F0 910 793 C HW: 4F0 959 793 C
Component: TSG FA H10 0020
Revision: 00000000 Serial number: 3•
Coding: 0000522
Shop #: WSC 02327 785 00200
Address 46: Central Conv. Labels: 4F0-910-289.lbl
Part No SW: 4F0 910 289 D HW: 4F0 907 289 D
Component: Komfortgeraet H14 0090
Revision: 00900014 Serial number: 01000454630000
Coding: 0000133
Address 47: Sound System Labels: 4F0-910-223-AS.lbl
Part No SW: 4F0 910 223 B HW: 4F0 035 223
Component: Amp.-ASK H09 0270
Revision: 14S00001 Serial number: 00207040016669
Coding: 0000006
Address 4F: Centr. Electr. II Labels: 4F0-910-280.lbl
Part No SW: 4F0 910 280 HW: 4F0 907 280
Component: ILM Beifahrer H07 0040
Revision: Serial number: 00000000012179
Coding: 0001004
Address 52: Door Elect, Pass. Labels: 4F0-910-793-52.lbl
Part No SW: 4F0 910 792 C HW: 4F0 959 792 C
Component: TSG BF H10 0020
Coding: 0000522
Address 53: Parking Brake Labels: 4F0-910-801.lbl
Part No SW: 4F0 910 801 HW: 4F0 907 801
Component: EPB C63C0030 H03 0030
Revision: C63C0030
Coding: 0002011
Address 56: Radio Labels: 4E0-910-541.lbl
Part No SW: 4E0 910 541 C HW: 4F0 035 541
Component: TUNER EU/US/RDW H41 0290
Revision: 00000000 Serial number: 352GY047545776
Coding: 0000001
Address 61: Battery Regul. Labels: 4F0-910-181.lbl
Part No SW: 4F0 910 181 E HW: 4F0 915 181 A
Component: ENERGIEMANAGER H11 0490
Revision: 00000000 Serial number: 00000000029370
Part No: 4F0 915 105 B
Component: von MLA 0407290095
Coding: 34463039313531303542204D4C4130343037323930303935
Shop #: WSC 00000 640 00290
Address 62: Door,Rear Left Labels: 4F0-910-795.lbl
Part No SW: 4F0 910 795 A HW: 4F0 959 795 A
Component: TSG HL H09 0010
Coding: 0000002
Address 72: Door, Rear Right Labels: 4F0-910-795.lbl
Part No SW: 4F0 910 795 A HW: 4F0 959 794 A
Component: TSG HR H09 0010
Coding: 0000002
Address 76: Park Assist Labels: 4F0-910-283.lbl
Part No SW: 4F0 910 283 F HW: 4F0 919 283 F
Component: Parkhilfe 4-Kan H09 0060
Revision: 00H09000 Serial number: 06240733002327
Coding: 0001006
Shop #: WSC 12345 123 12345
Address 77: Telephone Labels: 4E0-910-336.lbl
Part No SW: 4E0 910 336 B HW: 4E0 862 335
Component: Handyvorb2 H10 0080
Revision: 00000000 Serial number: 00000007515737
Coding: 0010900
End ---------------------------------------------------------------------
hallo! sebastian!
könntest du mir bitte sagen ob eine optische anzeige sich mit diesem steuergerät freischalten lässt?
und was sind das für fehler beid adresse 07 ?
