  4. Mercedes
  5. CLK, CLE & E-Klasse-Coupé
  6. W208
  7. Front glass washer nozzles
Mercedes CLK 208 Cabrio
Themenstarteram 1. Dezember 2024 um 16:30
Greetings everyone, the front window washer nozzles almost no longer work. I've already done everything I can but they're broken down in the attack.
They are heated.
I ordered 2 similar Chinese spare parts not heated (6 euros) and I'm waiting, does anyone have experience with these spare parts?
Thank you
18 Antworten
sorry, no Experience.
But, what can go wrong with cheap copy-parts? They can be to big, not fitting realy good. Why not buying cheap-used parts?
Leichti
"I ordered 2 similar Chinese spare parts not heated (6 euros)".
That sure seems to be worth a try, compared to this here offer...
https://www.ebay.de/itm/375821016620?...
Themenstarteram 1. Dezember 2024 um 20:20
@V8CLK430 schrieb am 1. Dezember 2024 um 20:57:23 Uhr:
Precisely for this reason I decided to try the Chinese ones.
Used they would have the years of mine to throw away...so no.
I also thought about applying a type that suits the purpose to the windshield wiper arm, any suggestions?
Thank you
6 and 120€, what a difference. I would also try first the probably Chinese junk. The price on eBay is just ridiculous.
Price for new original parts is 40,32€ each: https://...nalteile.mercedes-benz.de/.../a2088601147
Themenstarteram 2. Dezember 2024 um 13:48
A2118601147 and A2118600147 are the same ?
Well,
the original EPC Partnumbers are:
A2088601147 = right
and
A2088601247 = left
I had the washer nozzles on the wiper arm of the Chrysler LeBaron convertible.
It actually worked quite well, but the car was already 25 years old 10 years ago, so I sold it.
So spare parts will be even harder to come by if you want to convert your wiper arm,
"had the washer nozzles on the wiper arm of the Chrysler LeBaron convertible".
Warum nur erinnert mich das an den Car*toon weiter unten... :D
Why does this obsessively remind me of the cartoon below... :p
1
Versteh ich nicht, die Wischwasserdüsen beim LB waren wirklich am Wischerarm und haben direkt vor den Wischer gesprüht, das hat auch ganz gut funktioniert und es kam kein Wischwasser beim offen fahren über die WS Scheibe. Das hat mich damals ein bisschen begeistert, der A208 hat das nicht.
Allerdings hatte der Baron auch keinen Hubwischer wie es der Mercedes hat.
Beheizt waren die auch nicht.
Der cartoon mit den Senioren (Sensoren) war
eine Anspielung auf dieses hervorragende Produkt:
https://www.ebay.de/itm/305782604785?...
Eine Idee aus den 1970er Jahren, ich hätte nie vermutet dass
so etwas nach 50 Jahren immer noch produziert & angeboten wird... :p :D
Dann,
fehlt ja nur noch ein elastischer Spiralschlauch um,
...den Hub des Wischerarms zu kompensieren... :eek: :cool:
1
Themenstarteram 7. Dezember 2024 um 14:14
A 211 8601147 / A 208 8601147 are the same ?
They are also interchangeable DX / SX ?
https://www.amazon.it/.../B0BQQXWKW7
"A 211 8601147 / A 208 8601147 are the same" ?
...positively NOT . (at all)
The A 211 8601147 were built/used in the Next
generation production line, which is W203; W209; W211; W219
The A 211 8601147 are NOT Interchangeable with
the predecessor production line, which is W202; W208; W210
You've got to get A2088601147 = right and A2088601247 = left
Best of luck. :)
1
Themenstarteram 31. Januar 2025 um 6:11
They arrived and... they are very small.
I very much doubt they will cover the hood hole.
Would these work as an alternative? 1248600647
