- Passat
- Passat B6
- Gen 1 ACC - B7 Lane Assist
Hello! Sorry for talking in English, but I don't undestand German.
As my car has gen1 acc and 3AA lane assist camera, my lane assist is not working. It tells that "lane assist currently not available". As soon i disconnect my ACC radar, then lane assist starts working.
gen1 acc radar generates implausible signal to Lane assist:
Address A5: Frt Sens. Drv. Assist (R242) Labels: 3AA-980-654.clb
Part No SW: 3AA 980 654 D HW: 3AA 980 654 A
Component: MFK_Gen1 H09 0300
Serial number: 0187948448
Coding: 010101000102020D0201040000000000
Shop #: WSC 66565 257 00032
ASAM Dataset: EV_47X 001639
ROD: EV_47X.rod
VCID: 3979DFA1B85F10F7FE-806C
1 Fault Found:
3276800 - Databus
U1122 00 [009] - Implausible Message
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Reset counter: 174
Mileage: 16533 km
Date: 2015.07.07
Time: 18:10:00
Has anyone got such setub working? Problem is that I have PD engine that does not support gen 2 ACC radar (except one G SWX soft radar that is almost impossible to find). So gen2 radar for me is almost impossible... Now I'm looking for other solutions.. for example some kind of front assist emulator (If i have understood correctly, then 3AA lane assist is waiting for front assist signal... not 100% sure) or some kind of can filter before lane camera that should remove ACC signal from powertrain can.
If someone has done it or has idea how to make emulator/filter or smth, then please let me know.
My ACC radar:
Address 13: Auto Dist. Reg Labels: None
Part No SW: 3C0 907 567 L HW: 3C0 907 567 L
Component: AC201 RDW 1 031 0120
Revision: 00031000 Serial number: 00000000018465
Coding: 0010000
Shop #: WSC 52203 462 80134
VCID: 3467EE95573DED9F2D-8060
No fault code found.
I'll add googletranslated text here also:
Hallo! Es tut uns leid für das Gespräch in Englisch, aber ich weiß nicht Deutsch verstehen.
Da mein Auto hat gen1 acc und 3AA lane assist Kamera, mein lane assist arbeitet nicht. Es sagt, dass "lane assist zur Zeit nicht verfügbar". Sobald ich meine trennen ACC-Radar, dann Lane Assist arbeiten beginnt.
gen1 acc Radar erzeugt unplausibles Signal zur Fahrspurassistent.
Hat jemand eine solche Einstellung Arbeits? Problem ist, dass ich PD-Engine, die Gen 2 ACC-Radar nicht unterstützt (außer einem G SWX weichen Radar, die fast unmöglich zu finden ist). So gen2 Radar für mich fast unmöglich ... Jetzt bin ich auf der Suche nach anderen Lösungen .. beispielsweise eine Art Front Assist-Emulator (wenn ich richtig verstanden habe, dann 3AA lane assist wartet Front Assist Signal nicht ... 100% sicher) oder eine Art kann vor lane Kamera, die ACC-Signal von Antriebsstrang entfernen sollte filtern.
Wenn jemand hat es getan oder nur Ahnung, wie man Emulator / Filter oder smth zu machen, dann lass es mich wissen.
16 Antworten
You need G2 ACC!
@konrad3C schrieb am 13. November 2015 um 18:39:22 Uhr:
You need G2 ACC!
Yeah, it would be so simple if there were many G SWX radars. But I havent seen one yet. Thats why i'm thinking if there is some kind of other possibility to emulate or filter extra messages...
Or maybe someone has G SWX software or ever whole radar for sale?
Yeah 2gen, but 2gen radars won't work with PPD engine. Do they?
Supposedly index G radar with X Software can work with PPD and also have front assist and ACC until stop. PPD acc only to 30kmh
Adresse 13: Distanzregelung Labeldatei: PCI\3C0-907-567.clb
Teilenummer SW: 3C0 907 567 G HW: 3C0 907 567 G
Bauteil: AC201 RDW A 031 X221
Revision: 00031000 Seriennummer: 00000000011899
Codierung: 0010000
Betriebsnr.: WSC 12345 123 12345
VCID: 2F692B43BEB41160886
Kein(e) Fehlercode(s) gefunden.
What kind of chip is in the acc module? Can't we just get sw from a swx221 module?
I've read that the radar uses a TMS470 chip (please correct me if I'm wrong).
That chip has an internal flash area, which can be protected to prevent reading of the content from outside.
If the security option is used, there is no known way to get the sw from an ACC sensor.
I've only seen scans with SWX software from Petrol engines. Maybe Diesel had also swx radar?
One scan i saw was from 3.2-axz. When such G radar gets destroyed then it will be replaced with M radar. And the ECU will get replaced or SW update i guess by dealer.
@bronken schrieb am 29. sep. 2016 um 11:36:47 Uhr:
Wrong
Ok. Was ist es dann??
Glaub hitachi
Der scan von dem axn war meiner. Dennoch liegt es gar nicht an der x software.
Woran denn?
Weiss ich nicht aber die software kann es nicht sein
Ich habe das bisher so verstanden, dass wenn man ein Gen.2 ACC hat, das mit einem PPD Diesel funktioniert, mit einer aktuellen SW flasht, dieses nicht mehr mit einem PPD Diesel geht. Daraus wurde immer der Schluss gezogen, dass der entscheidende Unterschied in der SW liegt.
Ist dem denn nicht so?
Je mehr ich versuche, Informationen aus den verschiedenen Quellen zusammen zu tragen, um so wiedersprüchlicher werden diese leider.
Darum an dieser Stelle meine BItte, ob diejenigen, die sich wirklich mit der Materie auskennen, nich mal Licht ins Dunkel bringen können?
Fragestellung ist wie bekannt: wie kann man einen BMR Motor, ACC und die B7 MuFu Kamera zusammen in Funktion bringen?
Gesichert scheint bisher im Wesentlichen, was nicht geht: so z.B. ein schlichtes Update des ACC auf SW 0243 / 3C0907567M. UNklar ist dagegen, was denn nun wirklich geht: mal heisst es, es muss auf jeden Fall ein 3C0 907 567 G mit SW X221 sein (siehe oben), an andere Stelle heisst es dann ganz allgemein, dass auch andere gehen, und zuletzt dann dass es gar icht an der SW des ACC liegt.
Wie/woran man ein geeignetes ACC am Besten vor dem Kauf erkennt (ausser Label mit SWX221), wäre ein wertvoller Hinweis...
Den FrontAssist und follow-to-stop kann man im SW02xx ACC deaktivieren. Ob dann ein HW20 ABS ausreicht, oder zwingend ein HW25/26 ABS notwendig ist, ist für mich allerdings unklar.
Ein ganz anderer Ansatz der mir über den Weg gelaufen ist, wäre eine 3AA980654 MuFu Kamera mit SW00xx, das konnte ich aber bislang nicht testen.
Ich weiss, manche die hier fundiertes Wissen haben, sind kein Freund vieler Worte...
Es würde aber sicher nicht nur mir weiter helfen.
