- Audi
- A5
- A5 8T & 8F
- No contact whit MOST after opgrade to 3G
Hello
I upgraded from Symphony for MMI 3G in my A5 2009 model.
My problem is that I can not contact the MOST with VCDC.
All fiber directions are checked and are ok.
I also missing light in the following things.
Headunit ( the units can load / Eject )
MMI control panel
I can use a little help here :O)
31 Antworten
Do you have changed the Gateway and replaced it with the correct type?
YES, the gate way have index Q.
I don't know "Q". I think you need "AA" or higher... (SW 101 or higher)
I also testet this one, same same.
Part No SW: 8T0 907 468 P HW: 8T0 907 468 K
Component: GW-BEM 4CAN-M H09 0095
Revision: EB500046 Serial number: 4600E113090265
Coding: 000303
Shop #: WSC 77777 777 77777
VCID: 4E98D48919CC043
Subsystem 1 - Part No SW: 8K0 915 181 B HW: 8K0 915 181 B
Component: J367-BDM H04 0150
This has the SW 095. I don't know if it will work propperly with MMI3G.
Are there any faults shown in the ECU/Gateway?
Do you have marked the right component list (Verbauliste) in the Gateway? You need ECU 5F.
Monday,06,February,2012,16:38:10:35999
VCDS Version: Release 11.11.2
Data version: 20120126
Chassis Type: 8T0
Scan: 01 03 05 06 08 09 10 15 16 17 19 36 42 46 47 52 53 55 56 5F
69
VIN: WAUZZZ8T39A028427 Mileage: 92950km/57756miles
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: Malfunction 0010
06-Seat Mem. Pass -- Status: Malfunction 0010
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: Malfunction 0010
15-Airbags -- Status: Malfunction 0010
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
36-Seat Mem. Drvr -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: Malfunction 0010
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: Malfunction 0010
53-Parking Brake -- Status: Malfunction 0010
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
69-Trailer -- Status: Malfunction 0010
Address 01: Engine (MA---CDNB) Labels: 06H-907-115-CAB.clb
Part No SW: 8K2 907 115 Q HW: 8K2 907 115 D
Component: 2.0l R4/4V TF H14 0004
Revision: E1H14---
Coding: 0114000C18070960
ASAM Dataset: EV_ECM20TFS8K2907115Q A01006
ROD: EV_ECM20TFS8K2907115Q.rod
VCID: 3D7A8345AC6A8FB
No fault code found.
Readiness: 1110 0101
Address 03: ABS Brakes Labels: None
VCID: 55AA3BE5BC1A77B
No Faults Found
or DTCs not supported by controller
or a communication error occurred
Address 05: Acc/Start Auth. (J393) Labels: 8K0-907-064-05.clb
Part No SW: 8K0 907 064 A HW: 8K0 907 064 A
Component: BCM2 1.1 H80 0143
Revision: 00002001
Coding: 030000
Shop #: WSC 06325 000 00000
VCID: 2E58B409790C643
Subsystem 1 - Part No SW: 8T0 959 754 D HW: 8T0 959 754 D
Component: FBSAUDIB8 IDG H37 0060
Subsystem 2 - Part No SW: 8K0 905 852 D HW: 8K0 905 852 D
Component: ELVAUDIB8 H36 0041
Address 06: Seat Mem. Pass (J521) Labels: None
Part No SW: 8T0 959 760 B HW: 8T0 959 760 B
Component: MEM-BFS H09 0043
Revision: AA000000 Serial number: 00001001084897
Coding: 00017025002C44440000
VCID: 4280F0B9DD94F03
1 Fault Found:
02095 - Component Protection Active
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 2
Mileage: 92955 km
Time Indication: 0
Date: 2008.06.01
Time: 05:55:19
Address 08: Auto HVAC (J255) Labels: Redir Fail!
Part No SW: 8T1 820 043 P HW: 8T1 820 043 P
Component: KLIMA 1 ZONE H05 0120
Revision: A1000000 Serial number: 0117.11.070017
Coding: 46020000
Shop #: WSC 38564 128 28888
VCID: 3E788449A96C943
1 Fault Found:
00898 - Control Circuit A/C compressor
008 - Implausible Signal
Freeze Frame:
Fault Status: 01101000
Fault Priority: 6
Fault Frequency: 1
Reset counter: 2
Mileage: 92955 km
Time Indication: 0
Date: 2008.06.01
Time: 05:55:28
Freeze Frame:
Current: 0.000 A
Current: 0.510 A
Voltage: 14.10 V
Address 09: Cent. Elect. (J519) Labels: 8K0-907-063.clb
Part No SW: 8K0 907 063 BE HW: 8K0 907 063 P
Component: BCM1 1.0 H30 0400
Revision: 10030001 Serial number: 00000000979921
Coding: 2600D2110434AF000005000300005D5D031C228800000101000000
VCID: 73EE657DD2AE09B
Subsystem 1 - Part No SW: 8T1 955 119 C HW: 8J1 955 119 Labels: 1KX-955-119.CLB
Component: WWS 231008 H13 0040
Coding: 00FD11
Subsystem 2 - Part No SW: 8K0 955 559 HW: 8K0 955 559 Labels: 8K0-955-559.CLB
Component: RLS H04 0003
Coding: 02532C
Subsystem 3 - Part No SW: 8K0 941 531 G HW: 8K0 941 531 G
Component: E1 - LDS H07 0070
1 Fault Found:
03175 - Invalid Data Set
000 - -
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 2
Mileage: 92955 km
Time Indication: 0
Date: 2008.06.01
Time: 05:55:00
Address 10: Park/Steer Assist (J446) Labels: 8K0-919-475.clb
Part No SW: 8K0 919 475 AA HW: 8P0 919 475 N
Component: PARKHILFE 8K H01 0081
Revision: 11001001 Serial number: 12591113810946
Coding: 100001
VCID: 78F45251CBC86A3
Address 15: Airbags (J234) Labels: 8K0-959-655.clb
Part No SW: 8K0 959 655 B HW: 8K0 959 655 B
Component: AirbagVW-AU10 H27 0410
Serial number: 0038JD1C0WFH
Coding: 30313433363030303030554A304C38543053
ASAM Dataset: EV_AirbaECUVWAUDI010 A02007
ROD: EV_AirbaECUVWAUDI010_AU48.rod
VCID: 3C7C8E41B770863
Crash sensor for side airbag; driver side:
Serial number: 6334MSME41250A667
Crash sensor for side airbag; passenger side:
Serial number: 6344MSME4124457DE
Crash sensor for side airbag; rear driver side:
Serial number: 6352QSME6B102B24E
Crash sensor for side airbag; rear passenger side:
Serial number: 6362QSME230F50205
Crash sensor for front airbag; driver side:
Serial number: 63732SME7C100E34/
Crash sensor for front airbag; passenger side:
Serial number: 63832SME3C103E0C2
Address 16: Steering wheel (J527) Labels: 8K0-953-568.clb
Part No SW: 8K0 953 568 F HW: 8K0 953 568 F
Component: Lenks.Modul H13 0013
Revision: -------- Serial number: 90319HJP000E5
Coding: 000016
Shop #: WSC 12345 123 12345
VCID: 3D7A8345A46A8FB
Component: E221 - MFL H02 0003
Address 17: Instruments (J285) Labels: 8T0-920-xxx-17.clb
Part No SW: 8T0 920 900 J HW: 8T0 920 900 J
Component: KOMBIINSTR. H30 0224
Revision: 00000000 Serial number: 9CV20DMA8
Coding: 0F0500000200000C010000
VCID: 3A708859B544B83
1 Fault Found:
000 - -
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 2
Mileage: 92955 km
Time Indication: 0
Date: 2008.06.01
Time: 05:56:28
Address 19: CAN Gateway (J533) Labels: 8T0-907-468.clb
Coding: 000303
1 Fault Found:
02084 - Component Protection
005 - No or Incorrect Basic Setting / Adaptation
Freeze Frame:
Fault Status: 01100101
Fault Priority: 1
Fault Frequency: 1
Reset counter: 0
Mileage: 92940 km
Time Indication: 0
Date: 2008.05.27
Time: 00:36:05
Address 36: Seat Mem. Drvr (J136) Labels: None
Component: MEM-FS H09 0042
Revision: AA000000 Serial number: 00001001028072
Coding: 00017025002C44110000
1 Fault Found:
000 - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 2
Mileage: 92955 km
Time Indication: 0
Date: 2008.06.01
Time: 05:56:47
Address 42: Door Elect, Driver (J386) Labels: 8K0-959-793.clb
Part No SW: 8K0 959 793 E HW: 8K0 959 793 E
Component: TSG FA H11 0250
Revision: Serial number: 0000007858639
Coding: 011002224000120102
Address 46: Central Conv. (J393) Labels: 8K0-907-064-46.clb
Revision: 00002001 Serial number: 0115071110
Coding: 0100068008390040013000
1 Fault Found:
03219 - Access and Start Authorization
013 - Check DTC Memory
Freeze Frame:
Fault Status: 01101101
Fault Priority: 6
Fault Frequency: 1
Reset counter: 2
Mileage: 92955 km
Time Indication: 0
Date: 2008.06.01
Time: 05:57:06
Address 47: Sound System
Cannot be reached
Address 52: Door Elect, Pass. (J387) Labels: 8K0-959-792.clb
Part No SW: 8K0 959 792 E HW: 8K0 959 792 E
Component: TSG BF H11 0250
Revision: Serial number: 0000007856236
VCID: 4182FFB5D892EBB
Address 53: Parking Brake (J540) Labels: 8K0-907-801.clb
Part No SW: 8K0 907 801 E HW: 8K0 907 801 E
Component: EPB Audi B8 H05 0060
Revision: 00000003 Serial number: 00000000249601
Shop #: WSC 00000 000 00000
VCID: 3162AF7568327BB
Address 55: Xenon Range Labels: 8K0-907-357.clb
Part No: 8K0 907 357
Component: Dynamische LWR H01 0010
Revision: 00000001 Serial number:
Coding: 0000002
VCID: F2E0E079EDB4803
Address 56: Radio
Cannot be reached
Address 5F: Information Electr.
Cannot be reached
Address 69: Trailer (J345) Labels: 8K0-907-383.clb
Part No SW: 8K0 907 383 E HW: 8K0 907 383 E
Component: Anhaenger H09 0100
Revision: 1A001001 Serial number: 00000159166490
Coding: 0100000000000000
VCID: 36689C69815C5C3
End ---------------------------------------------------------------------
It's difficult to say... the gateway finds the 5F, 56 and 47. Perhaps, because "Component Protection active"?
But I see, that you have retrofit Xenon, correct? I think you've choosen the wrong Centr. Electric. ECU, because your's for MJ 2010 or newer.
And the HVAC will not work with the MMI3G (no displayed settings), it's to old for that. You need SW 140 or higher. (AA)
yes i have retrofit xenon.
What centr-elek do i need to test?
What is HVAC?
Index D or J,
What is HVAC?
Climate Control
Do you have one in stock?
Index D or J,Zitat:
Climate ControlZitat:
What is HVAC?
You can see the SW on your VCDS Scan:
Code:
Coding: 46020000
I have no Centr. Electr. in Stock...but I think this is not the problem with your MMI3G.
I think you have to deactivate the component protection and then we can look after the problems...
Tomorrow I get a new central electronic D / J I will try it.
MMI should work with protection on, but with reduced functionality?
can you tell us the partnumbers of all your MMI3G components?
Does something work on your MMI screen?
