SW 17.x
weiss jemand was an dieser Version neu bzw. besser ist?
20 Antworten
Ausschnitt aus dem englischen Forum:
The following software errors were corrected with the release of CIP 17.0 (Target data Status E060-05-03-520).
E60: Battery keeps getting discharged. Carrying out "Energy Diagnosis" test plan, the (aLBV) "active seat back width adjustment" has been recognized as the sleep mode preventer. Recode the complete vehicle.
The following software errors were corrected with the release of CIP 16.1 (Target data Status E060-05-03-520).
On certain MY 2005 vehicles, equipped with the 4.4liter N62 engine, the engine oil CBS message comes on at a very low mileage. Refer to SM B12 213 05.
E60: Exterior lights flash briefly when vehicle wakes up. Refer to SM B63 207 04.
Vehicles equipped with CCC reboot upon startup (CID screen switches from BMW to blank screen).
While placing a call with a Bluetooth handset the call ends after 30 seconds. The timer was extended. Refer to SM B84 234 04.
Airbag Warning light is on and one or more of the following "timeout" or "self test" faults is stored:
Safety Information Gateway Module (SGM) FC 93AE, 93B0, 93B2, 93B4, 93B6, 93B8, 93B9, 93BA, 93BC, 93BD, 93BE, 93BF, 93C0, 93E4, 93F4, 9445, 9446, 9447, 9448, 9449, 944A
Other satellite modules may also store "timeout" or "self test" faults that may mirror the fault in the SGM.
Audio off or mute mode is not stored on CCC vehicles after sleep mode. Affected vehicles: E60 (5 Series with CCC), E63/E64 (6 Series). Refer to SM B65 228 04.
Not all the CD's can be selected in the CD changer, even though all 6 CD's are loaded.
Controller rotates on it's own without being operated.
The navigation map is displayed in the assist window (right hand window) on the CID. When the engine is switched off, after 45 minutes the on board computer is displayed instead of the map.
Vehicles equipped with CCC and CPT9000 telephone, the missed call indicator is missing, although when the menu is called up the telephone number and time of call are displayed.
The PDC tone and gongs are twice as loud following a CCC replacement (vehicles with SA 677 Professional HiFi sound system).
When automatic headlamp mode is used, the lights switch on as the vehicle enters a tunnel but do not switch off again after leaving the tunnel. Refer to SM B63 201 05.
Loss of power when decelerating and turning or coming to a stop. Vehicles equipped with N62 engine with SMG GS6-53BZ transmission. Refer to SM B12 201 05.
Ventilation temperature too cold. Refer to SM B64 202 05.
Gruß,
Sascha
Ich kann 7 Sprachen perfekt - aber nur pfeifen!
Vielleicht kann das mal einer Stichpunktmäßig ins lesbare deutsch übersetzen.
der Klempner
Das soll heissen:
Alles wird gut!
hab ich mir´s doch gleich gedacht
Ganz kurz:
Fehler: Entladen der Batterie
545i: Fehlerbehebung Öl-Lampe brennt
Fehler: Kurzes Aufblinken der Lichter beim Anmachen des Autos
Bei CCC: Kein Neustart mehr nach dem Starten des Autos
Fehler: Verbindungsabbruch nach 30s bei Bluetooth
Fehler: Airbag Lampe brennt
Fehler: Radio wieder an nach Neustart, obwohl ausgemacht zuvor (bei CCC)
Fehler: Es können nicht alle CDs im Wechsler ausgewählt werden.
Fehler: I-Drive-Controller dreht sich alleine, ohne bedient zu werden.
Fehler: Die Navi-Karte wird auf das Assistenten-Fenster rechts eingeblendet und nach 45min und einem Neustart wurde das nicht gespeichert - der BC ist wieder eingeblendet
Fehler: CCC und Telefon Pro: Die Anzeige für verpasste Anrufe fehlt
Fehler: PDC und Gong ist doppelt so laut, gefolgt von einem Wechsel des CCCs (nur mit HiFi System)
Fehler bei Auto-Licht: Beim Einfahren eines Tunnels geht das Licht an, aber nicht mehr aus nach dem Herausfahren
Fehler: Stromausfall bei SMG Getriebe nach einer Fahrt und anschließendem Stop
Fehler: Belüftung zu kalt
Gruß,
Sascha
Wofür steht CCC und SZL? DANKE!
CCC = Car Communication Computer = Navi Professional. CCC steht immer nur für Navi Pro, hat nix mit dem Business zu tun
SZL ? Wo steht das?
SZL muss ein Steuergerät sein - steht auf einem Update-Statusbericht
"Lüftung zu kalt"?
Ich finde eher, daß jetzt "Lüftung zu warm"
Original geschrieben von Sascha_525d
Ganz kurz:
Gruß,
Sascha
Sind es alle Modelle betroffen oder nur die mit aktiven Sitzen?
Peter
Also doch keine "Leistungssteigerung" auf die alte Leistung beim Diesel???????
Mit CIP 17.0 wird an Getriebe und Motormanagement nichts geändert, außer CIP Stand Fahrzeug <16.x. Aktuell sind wir bei CIP 17.1, wieder kleine Änderungen bei der Getriebesteuerung aber noch KEINE Leistungsanhebung. Bin an der Sache drann und laß auch nicht locker. Versprochen!!
Peter
Nur mit Aktivsitze.
Gruß,
Sascha
