  3. Wissen
  4. Fahrzeugtechnik
  5. On-Board-Diagnose
  6. TT 8J viele Fehler im Protokoll!??
ISt das normal?
Wednesday,13,June,2007,15:29:00:17555
VAG-COM Version: Release 704.1
Data version: 20070422
Chassis Type: 1K0
Scan: 01 02 03 04 08 09 14 15 16 17 19 25 37 42 44 46 47 4C 52 55
56 57 76 77
VIN: TRUZZZ8J17103**** Mileage: 1610km/1000miles
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
14-Susp. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
37-Navigation -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: Malfunction 0010
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: Sporadic communication error 1000
47-Sound System -- Status: Malfunction 0010
4C-Tire Pressure II -- Status: OK 0000
52-Door Elect, Pass. -- Status: Malfunction 0010
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
57-TV Tuner -- Status: Not registered 0011
76-Park Assist -- Status: OK 0000
77-Telephone -- Status: Malfunction 0010
Address 01: Engine Labels: 06F-907-115-AXX.LBL
Part No SW: 8J0 907 115 HW: 8J0 907 115
Component: 2.0l R4/4V TFSI 0020
Coding: 011300031C070160
Shop #: WSC 01236
No fault code found.
Readiness: 0000 0000
Address 02: Auto Trans Labels: 02E-300-0xx.LBL
Part No SW: 02E 300 043 Q HW: 02E 927 770 AE
Component: GSG DSG 081 1302
Coding: 0000020
Shop #: WSC 01236
Address 03: ABS Brakes Labels: None
Part No SW: 8J0 614 517 HW: 8J0 614 517
Component: ESP MK60E1 0130
Coding: 0025616
Shop #: WSC 01236
1 Fault Found:
01299 - Diagnostic Interface for Data Bus (J533)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 51
Mileage: 1520 km
Time Indication: 0
Date: 2007.06.10
Time: 13:32:39
Freeze Frame:
Count: 64
Count: 12289
Count: 8233
Count: 45056
Address 08: Auto HVAC Labels: None
Part No SW: 8J0 820 043 AG HW: 8J0 820 043 AG
Component: J255 Klima 1 Zone 0080
Coding: 1572868
Shop #: WSC 01236
1 Fault Found:
01330 - Central Control Module for Central Convenience (J393)
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 51
Mileage: 1520 km
Time Indication: 0
Date: 2007.06.10
Time: 13:32:47
Freeze Frame:
ON
Address 09: Cent. Elect. Labels: 8P0-907-279.LBL
Part No SW: 8P0 907 279 H HW: 8P0 907 279 H
Component: Bordnetz-SG H46 1802
Coding: F1061E8280141C0003180000180000000009EE075A250802
Shop #: WSC 01236
Part No: 8J1 955 119
Component: Wischer AU354 H07 0060
Coding: 00064784
Shop #: WSC 01236
Part No: 4E0 910 557 A
Component: REGENLICHTSENSORH13 0090
Coding: 00149804
Shop #: WSC 01236
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 51
Mileage: 1520 km
Time Indication: 0
Date: 2007.06.10
Time: 13:32:00
Freeze Frame:
OFF
Voltage: 12.75 V
OFF
ON
OFF
OFF
OFF
Address 14: Susp. Elect. Labels: None
Part No SW: 8J0 910 376 HW: 8J0 907 376 A
Component: J250 Raddaempfung 0050
Coding: 0000021
Shop #: WSC 01236
Address 15: Airbags Labels: None
Part No SW: 8J0 959 655 HW: 8J0 959 655
Component: -s Airbag 9.43 H02 0020
Coding: 0011635
Shop #: WSC 01236
Address 16: Steering wheel Labels: 8P0-953-549.LBL
Part No SW: 8P0 953 549 F HW: 8P0 953 549 F
Component: J0527 H36 0070
Coding: 0014141
Shop #: WSC 01236
Part No: XXXXXXXXXXX
Component: E0221 H06 0030
Address 17: Instruments Labels: 8J0-920-xxx-17.LBL
Part No SW: 8J0 920 930 C HW: 8J0 920 930 C
Component: KOMBIINSTR. VDO H21 0070
Coding: 0080018
Shop #: WSC 00493
Address 19: CAN Gateway Labels: 1K0-907-530.LBL
Part No SW: 1K0 907 530 K HW: 1K0 907 951
Component: J533__Gateway H12 0170
Coding: 7F0F07CA67004100
Shop #: WSC 01236
2 Faults Found:
01044 - Control Module Incorrectly Coded
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 1
Fault Frequency: 2
Reset counter: 10
Mileage: 1146 km
Time Indication: 0
Date: 2007.06.08
Time: 17:37:57
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 51
Time Indication: 0
Date: 2007.06.10
Time: 13:32:23
Address 25: Immobilizer Labels: 1K0-920-xxx-25.LBL
Address 37: Navigation Labels: 8E0-035-192-RNSE.LBL
Part No SW: 8J0 035 192 HW: 8J0 035 192
Component: RNS-E HIGH EU H10 0570
Coding: 0619715
Shop #: WSC 00000
1 Fault Found:
000 - -
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 9
Mileage: 1146 km
Time Indication: 0
Date: 2007.06.08
Time: 17:38:01
Address 42: Door Elect, Driver Labels: None
Part No: 8J8 959 801 B
Component: Tuer-SG H02 0060
Coding: 0000053
Shop #: WSC 01236
1 Fault Found:
Address 44: Steering Assist Labels: 1Kx-909-14x.LBL
Part No: 8J1 909 143 B
Component: EPS_ZFLS Kl.157 H07 1807
Address 46: Central Conv. Labels: None
Part No: 8J0 959 433
Component: KSG H07 0070
Coding: 9890300201182D298505488A0167
Shop #: WSC 01236
Component: Sounder n.mounted
Component: NGS n.mounted
Component: IRUE n.mounted
Address 47: Sound System Labels: None
Part No SW: 8J0 035 223 C HW: 8J0 035 223 C
Component: J525 Amp High H04 0120
Coding: 0246114
Shop #: WSC 01236
1 Fault Found:
02753 - Inside Microphone (R74)
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 5
Fault Frequency: 3
Reset counter: 54
Mileage: 1592 km
Time Indication: 0
Date: 2007.06.11
Time: 18:43:55
Address 4C: Tire Pressure II Labels: 8J0-907-274.LBL
Part No SW: 8J0 907 274 HW: 8J0 907 274
Component: J502 RKA+ H04 0130
Coding: 0634100
Shop #: WSC 01236
Address 52: Door Elect, Pass. Labels: None
Part No: 8J8 959 802 B
Coding: 0000053
Shop #: WSC 01236
1 Fault Found:
Address 55: Xenon Range Labels: 8P0-907-357.LBL
Part No: 8P0 907 357 G
Component: Dynamische LWR H01 0010
Coding: 0000011
Shop #: WSC 01236
Address 56: Radio Labels: 8E0-035-192-RNSE.LBL
Coding: 0619715
Shop #: WSC 00000
1 Fault Found:
000 - -
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 9
Mileage: 1146 km
Time Indication: 0
Date: 2007.06.08
Time: 17:38:01
Address 57: TV Tuner
Cannot be reached
Address 76: Park Assist Labels: None
Part No SW: 8P0 919 283 D HW: 8P0 919 283 D
Component: Parkhilfe 4-Kan H09 0060
Coding: 0001031
Shop #: WSC 01236
Address 77: Telephone Labels: 8P0-862-335.LBL
Part No SW: 8P0 862 335 H HW: 8P0 862 335 H
Component: FSE_255x BT H26 0290
Coding: 0011411
Shop #: WSC 01236
1 Fault Found:
01523 - Microphone for Telephone (R38)
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 53
Mileage: 1592 km
Time Indication: 0
Date: 2007.06.11
Time: 18:44:13
End --------------------------------------------------------------------------------------------------
3 Antworten
Der vollständikeit halber auch hier die Lösung, auch wenn es sich um enen Multimedia-Adapter und keinen echten TV-Tuner handelt...
CAN-Gateway Codierung auf 7F0F07DA67004100.
RNS-E Codierung auf 0619716.
Beides sagt den Fahrzeugsystemen dann das der TV-Tuner verbaut ist, danach Fehler löschen und das sollte alles sein sofern nicht noch irgendwas auftaucht.
Update:
Mittwoch,13,Juni,2007,16:44:46:17555
VAG-COM Version: DRV 704.1
Datenstand: 20070602
Fahrzeugtyp: 1K0
Scan: 01 02 03 04 08 09 15 16 17 19 25 37 42 44 46 47 52 55 56 57
76 77
Fahrgestellnummer: TRUZZZ8J1 Kilometerstand: 1610km/1000miles
01-Motor -- Status: i.O. 0000
02-Getriebe -- Status: i.O. 0000
03-Bremsen -- Status: i.O. 0000
04-Lenkwinkel -- Status: i.O. 0000
08-Heizung/Klima -- Status: i.O. 0000
09-Bordnetz -- Status: i.O. 0000
15-Airbag -- Status: i.O. 0000
16-Lenkrad -- Status: i.O. 0000
17-Kombiinstrument -- Status: i.O. 0000
18-Standheizung -- Status: Fehler 0010
19-CAN-Gateway -- Status: i.O. 0000
25-Wegfahrsperre -- Status: i.O. 0000
37-Navigation -- Status: i.O. 0000
42-Türelektr. Fahrer -- Status: i.O. 0000
44-Lenkhilfe -- Status: i.O. 0000
46-Komfortsystem -- Status: i.O. 0000
47-Soundsystem -- Status: i.O. 0000
52-Türelektr. Beifahr. -- Status: i.O. 0000
55-Leuchtweitenreg. -- Status: i.O. 0000
56-Radio -- Status: i.O. 0000
57-TV Tuner -- Status: Fehler 0010
76-Einparkhilfe -- Status: i.O. 0000
77-Telefon -- Status: Fehler 0010
Adresse 01: Motor Labeldatei: DRV\06F-907-115-AXX.LBL
Teilenummer SW: 8J0 907 115 HW: 8J0 907 115
Bauteil: 2.0l R4/4V TFSI 0020
Codierung: 011300031C070160
Werkstatt #: WSC 01236
Kein(e) Fehler gefunden.
Adresse 02: Getriebe Labeldatei: DRV\02E-300-0xx.LBL
Teilenummer SW: 02E 300 043 Q HW: 02E 927 770 AE
Bauteil: GSG DSG 081 1302
Codierung: 0000020
Adresse 03: Bremsen Labeldatei: DRV\8J0-614-517.LBL
Teilenummer SW: 8J0 614 517 HW: 8J0 614 517
Bauteil: ESP MK60E1 0130
Codierung: 0025616
Adresse 08: Heizung/Klima Labeldatei: DRV\8J0-820-043.LBL
Teilenummer SW: 8J0 820 043 AG HW: 8J0 820 043 AG
Bauteil: J255 Klima 1 Zone 0080
Codierung: 1572868
Adresse 09: Bordnetz Labeldatei: DRV\8P0-907-279.LBL
Teilenummer SW: 8P0 907 279 H HW: 8P0 907 279 H
Bauteil: Bordnetz-SG H46 1802
Codierung: F1061E8280141C0003180000180000000009EE075A250802
Teilenummer: 8J1 955 119
Bauteil: Wischer AU354 H07 0060
Codierung: 00064784
Teilenummer: 4E0 910 557 A
Bauteil: REGENLICHTSENSORH13 0090
Codierung: 00149804
Adresse 15: Airbag Labeldatei: DRV\8J0-959-655.LBL
Teilenummer SW: 8J0 959 655 HW: 8J0 959 655
Bauteil: -s Airbag 9.43 H02 0020
Codierung: 0011635
Adresse 16: Lenkrad Labeldatei: DRV\8P0-953-549-F.LBL
Teilenummer SW: 8P0 953 549 F HW: 8P0 953 549 F
Bauteil: J0527 H36 0070
Codierung: 0014141
Teilenummer: XXXXXXXXXXX
Bauteil: E0221 H06 0030
Adresse 17: Kombiinstrument Labeldatei: DRV\8J0-920-xxx-17.LBL
Teilenummer SW: 8J0 920 930 C HW: 8J0 920 930 C
Bauteil: KOMBIINSTR. VDO H21 0070
Codierung: 0080018
Werkstatt #: WSC 00493
Adresse 19: CAN-Gateway Labeldatei: DRV\1K0-907-530.LBL
Teilenummer SW: 1K0 907 530 K HW: 1K0 907 951
Bauteil: J533__Gateway H12 0170
Codierung: 7F0F07DA67004100
Adresse 25: Wegfahrsperre Labeldatei: DRV\1K0-920-xxx-25.LBL
Adresse 37: Navigation Labeldatei: DRV\8E0-035-192-RNSE.LBL
Teilenummer SW: 8J0 035 192 HW: 8J0 035 192
Bauteil: RNS-E HIGH EU H10 0550
Codierung: 0619716
Werkstatt #: WSC 00000
Adresse 42: Türelektr. Fahrer Labeldatei: Keine
Teilenummer: 8J8 959 801 B
Bauteil: Tuer-SG H02 0060
Codierung: 0000053
Adresse 44: Lenkhilfe Labeldatei: DRV\1Kx-909-14x.LBL
Teilenummer: 8J1 909 143 B
Bauteil: EPS_ZFLS Kl.157 H07 1807
Adresse 46: Komfortsystem Labeldatei: DRV\8J0-959-433.LBL
Teilenummer: 8J0 959 433
Bauteil: KSG H07 0070
Codierung: 9890300201182D298505488A0167
Bauteil: Sounder n.mounted
Bauteil: NGS n.mounted
Bauteil: IRUE n.mounted
Adresse 47: Soundsystem Labeldatei: DRV\8J0-035-223.LBL
Teilenummer SW: 8J0 035 223 C HW: 8J0 035 223 C
Bauteil: J525 Amp High H04 0120
Codierung: 0246114
Adresse 52: Türelektr. Beifahr. Labeldatei: Keine
Teilenummer: 8J8 959 802 B
Codierung: 0000053
Adresse 55: Leuchtweitenreg. Labeldatei: DRV\8P0-907-357.LBL
Teilenummer: 8P0 907 357 G
Bauteil: Dynamische LWR H01 0010
Codierung: 0000011
Adresse 56: Radio Labeldatei: DRV\8E0-035-192-RNSE.LBL
Codierung: 0619716
Adresse 57: TV Tuner
nicht erreichbar
Adresse 76: Einparkhilfe Labeldatei: DRV\8P0-919-283.LBL
Teilenummer SW: 8P0 919 283 D HW: 8P0 919 283 D
Bauteil: Parkhilfe 4-Kan H09 0060
Codierung: 0001031
Adresse 77: Telefon Labeldatei: DRV\8P0-862-335.LBL
Teilenummer SW: 8P0 862 335 H HW: 8P0 862 335 H
Bauteil: FSE_255x BT H26 0290
Codierung: 0011411
1 Fehler gefunden:
01304 - Radio
004 - kein Signal/Kommunikation - Sporadisch
Umgebungsbedingungen:
Fehler Status: 00100100
Fehler Priorität: 5
Fehler Häufigkeit: 1
Verlernzähler: 55
Kilometerstand: 1611 km
Zeitangabe: 0
Datum: 2007.06.13
Zeit: 16:39:25
Ende --------------------------------------------------------------------------------------------------
Sieht doch gleich besser aus. :)
Nun noch den Fehler in der FSE löschen und dann wars das. ;)
