Wie man von einen 2.6 einen 3.2 AMG macht
For more information look at http://www.mercedesbenzclub.nl/gallery/album07
I took a 2.6 and build a EVO1 spoiler pakket on it with a 3.2 AMG engine in it and a complet new excaust system.
in the link above you can see what i have done in several years to upgrade my car last wish is tempomat and electric rollo rear, then i am finished building and have a full option car even with options that was not availleble for a W201
some special specifications I built
engine 3.2 AMG
BI-xenon
15 inch brake system from a C32 W203 front and rear
right and left seat electrical with memorie
dubbel excaust system from front til rear
SLK pedals
Left en right mirror full electrical movement and heated.
Airco
EVOI spoilers
4x AMG door lights
etc etc etc to much to call look for your self in above link from 2000 to 2004 maps
http://www.mercedesbenzclub.nl/albums/album128/DSCN4539.sized.jpg
11 Antworten
Hello,
tried to write to you here yesterday but it didn´t work.
I have a 300CE -88 with the 3.2 AMG engine from a 190 AMG.
I would be very glad if you "bombed" me with information about this engine. Have no owners manual, and it´s very difficult to find any info about this engine,,so I would be very glad if you could help me some.
Best wishes!
here are some engine facts... perhabs you allready know.
Motor type 6 Zyl in row 12 valves
Volume 3205ccm
Bohrung/Hub (i dont know the english word) (mm) 90,0 / 84,0
pressure 10,0
HP @ rpm 234 (5750)
Nm @ rpm 317 (4500)
tire size 205/50 R 16 (standard)
0-100 km/h (0-60 miles) 6,9 s
v max (km/h) 245
noise level 56 dB (A)
- @ 130km/h 72 dB (A)
fuel l/100km 16,3
oh okay... what are the changes you have done to the engine ?
sorry for mistakes
Thanks a lot!
I also wonder other datas like,,exactly how many litres of oil do I have to fill after an oil and filter change? I always fill in 6 litres,, should it be 6.5 litres?
I know,,I can check at the oilstick,,but just to be more sure you know
I also wonder if this engine has sensors..I mean..does it matter if I fill in 95 or 98 oktan fuel?
And how about spareparts for this engine? like camshafts and so,,where and how to find? ..impossible or?
So,,brothers in cars.. here´s an other problem I have.
Since 2 months, the yellow triangle in my "KI" flashes when I drive at low speed. This phenomen appears when I turn left/right (low speed). Sometimes the ABS lamp lightens too.
Had the car in a werkstatt today,,and 7100 SEK poorer,,tthe problem wasn´t solved. I had a bad feeling in my gut and unfortunately I was right. I asked the guy several times and he answered "Yes! it´s fixed,,the yellow triangle doesn´t flash anymore". I only drove some 100 metres and it started flashing again.
He had changed the ABS-control box he said,, I don´t even know what it is or where this thing is. I payed 2500SEK only for that part (used).
I just wonder,,where does this problem come from? It feels like my differential "greift an"..but I can´t understand why? I don´t spin, and the road is dry.
All this shitty problem started when I took out the KI to put in this damn chrome rings,,and I accidentally managed to take out the 15 hole main contact in a wrong way. First attempt to put the 15 small cables in each correct hole didn´t work well. Now they are put in right,,but this yellow triangle warning light and the differential living it´s own life seems to go on.
What can I have done? Have I burnt out some relay maybe? or are my ABS sensors bad?
It´s then so strange they got bad just that day when I failed after putting the KI back in order after the shitty chromringe job.
Sorry! gave you all a lot of kopfschmerz I think.
Tomorrow morning I leave the car again to the mechanic...but unfortuantelly I feel no hope.
Anyone have any idea?
Thanks for taking time and reading.
The yellow triangle is for ASD and not ABS....
Maybe the ASD relais is not working
Hello and thank you for answering,
I was by the werkstatt again and test drived the car,,now it seems that the problem is solved. The yellow triangle doesn´t light up anymore but now my ABS lamp lightens up after a couple of 100 metres driving,,but the ABS is not pumping for nothing like before. I left the car by the mechanic and he said he would fix that too.
What he had done was changing the ABS control box again,,and now the bigger part of the problem seems to be gone,,ASD doesn´t activate for nothing like it did before.
..So now I feel good again
sorry for mistakes
Ask Thorsten Stadler in Germany he did the work to my engine @ http://www.190teile.de/
also have a look at the engine @
http://www.mercedesbenzclub.nl/gallery/album80
http://www.mercedesbenzclub.nl/gallery/album80 http://www.190teile.de/
thank you,,I will take a look
The changes are that my car is originally a 300CE but some owner before me has converted the car and the engine by some tuner called Fred Laufer AMG-Essen.
So the engine is 3.2 litre AMG engine which I think comes oroginally from 190 AMG,, because according to what I know, AMG has not serie produced this car except the 3.4 litre W124.
And..I have an original AMG 280Km/h tacho+ spoilers and all.
Can mail you photos if you like?
best wishes!
best wishes!
all W124 everbuild look @ http://www.mercedesbenzclub.nl/gallery/album88/W124?full=1
W124 only had 3.6 AMG engines and the powefull V8 E60 AMG
pictures of that car you can see @ http://www.mercedesbenzclub.nl/gallery/album390
have funn with the pics
