- Opel
- Vectra
- Vectra C & Signum
- 2004 Signum 1.9 cdti P0002 (no other symptoms)
Maybe anyone here has encountered such an issue.
Its random as far as I can tell.
Whenever I turn the ignition key (and not start the engine), I get the error on the dashboard, when connecting through Torque app via simple OBD tool, I get P0002 code (I cant see the subcode if there is any).
Car starts with no issues and the error on dash immediately turns off (but stays in the ECU).
The car drives perfectly fine as far as I can tell, there is no limp mode or anything.
Whenever I clear the error, it can come out next day or same day. And it only shows up before the engine is on.
I was thinking of replacing both 0928400680 and 55576178 however as I read these parts, when faulty, most often have symptoms like fluctuating revs or limp mode etc.
any help would be appreciated :)
3 Antworten
looking into my list it's the following error
P0002 rail preasure => out of rated range
P0002 magnetic fuel valve => out of rated range
There is a problem with the fuel regulation system, it seems that the regulation valve is not properly working.
Best regards
Stephan
good morning
It may also be that the DTC/error code was read incorrectly!
As a normal OBD code it would be-
Error code P0002
Fuel Delivery Range/Performance Control Valve Circuit
Silent callbacks
The engine warning light is on
Check the following components
System components
Bosch, EDC16C39, with diesel particulate filter, (2007 - 2008)
Motor control
Solenoid valve mixture regulation
Fuel pressure sensor
As a manufacturer specific DTC/error code error code P1002
Injector 1 circuit low
System components
Motor control
Fuel pump with level sensor
Fuel pump relay
Kind regards
moin
Es kann auch sein das der DTC/Fehlercode falsch ausgelesen wurde!
Als normaler OBD Code wäre es-
Fehlercode P0002
Stromkreis Regelventil Kraftstoffförderung Bereich/Leistung
Stille Rückrufe
Die Motorwarnleuchte brennt
Die folgenden Komponenten prüfen
System Komponenten
Bosch, EDC16C39, Mit Dieselpartikelfilter, (2007 - 2008)
Motorsteuerung
Magnetventil Gemischregulierung
Krafstoffdrucksensor
Als Herstellerspezifischer Dtc/Fehlercode Fehlercode P1002
Stromkreis Einspritzventil 1 niedrig
System Komponenten
Motorsteuerung
Kraftstoffpumpe mit Niveausensor
Kraftstoffpumpenrelais
@rosi03677 thanks a lot, that actually makes some sense for pump level senor or pump relay, because the mixture valve would not be included in this part as engine is not yet started. it could also be the pressure sensor of course.
I will check with the repair shop
