Audi S7 ACC Diagnose
Guten Tag ihr Lieben.
Bin jetzt in der Phase angelangt wo ich die Laempchen aus meinem Kombiinstrument haben will.
Problem ist mein ACC.
Hab hier mal den Auszug vom Fehlerspeicher:
Car Scanner ELM OBD2
Version: 1.100.2/401002/GP
DTC report
Connection profile: Audi OBD-II / EOBDDate: 10/12/2023 5:43:56 PM
VIN: WAU32AFC0DN102239
19. CAN Gateway19. CAN Gateway
DTCs: 1
04365 [0x00110D]
U023500: Lost Communication With, Cruise Control Front Distance Range Sensor
Abstandsdistanzregelung keine Kommunikation
Status bits: 1
Priority: 2
Frequency: 1
Unlearning index: 65
Odometer: 143644 km
Date, time: 2023.10.12 15:12:41
Status: Test failed, Confirmed
09. Onboard supply control unit
No DTC found.
02. Transmission control unit02. Transmission control unit
DTCs: 1
20361 [0x004F89]
U010400: Lost Communication With Cruise Control Module
Status bits: 1
Priority: 6
Frequency: 1
Unlearning index: 40
Odometer: 143644 km
Date, time: 2023.10.12 15:12:44
Engine RPM: 662 rpm
Calculated engine load value: 0.78 %
Vehicle speed: 150 km/h
Engine coolant temperature: -40 ?
Engine oil temperature: -40 ?
Barometric pressure: 26 kPa
Klemme 30 voltage: 29
Status: Test failed, Test failed (current drive cycle), Pending, Confirmed, Test failed since last DTC clear
03. ABS control unit03. ABS control unit
DTCs: 2
00040 [0x000028]
U111100: Function limitation due to missing message
ComScl_PDU_ACC_05_Timeout
Status bits: 1
Priority: 6
Frequency: 1
Odometer: 143644 km
Date, time: 2023.10.12 15:12:42
00042 [0x00002A]
ComScl_PDU_ACC_10_Timeout
Status bits: 1
Priority: 6
Frequency: 1
Odometer: 143644 km
01. Engine control unit01. Engine control unit
DTCs: 4
17881 [0x0045D9]
P047700: Exhaust Pressure Control Valve "A" Low
Status bits: 1
Priority: 2
Frequency: 1
Unlearning index: 255
Odometer: 143675 km
Date, time: 2023.10.12 17:15:45
Engine RPM: 0 rpm
Calculated engine load value: 0.00 %
Vehicle speed: 0 km/h
Engine coolant temperature: 170.6 ?
Engine oil temperature: 147.2 ?
Barometric pressure: 97 kPa
Klemme 30 voltage: 11
Paramteric values: 20 96 28 10 7A 01 11 BD 0D 5B 13 38 05 12 16 0A 5E 15 14 04 12 6E 0E 45 10 10 00 00
Status: Test failed, Test failed (current drive cycle), Pending, Test failed since last DTC clear
17875 [0x0045D3]
P047500: Exhaust Pressure Control Valve "A"
Status bits: 1
Priority: 2
Frequency: 1
Odometer: 143644 km
Engine RPM: 671 rpm
Calculated engine load value: 7.45 %
Engine coolant temperature: 204.8 ?
Engine oil temperature: 150.8 ?
Barometric pressure: 99 kPa
Klemme 30 voltage: 13
Paramteric values: 20 96 28 10 7A 03 11 BD 0E 50 13 38 05 12 16 04 2B 15 14 04 12 6E 04 1E 10 10 03 B2
Status: Pending, Confirmed, Test failed since last DTC clear
17876 [0x0045D4]
P049F00: Exhaust Pressure Control Valve "B"
Status bits: 1
Priority: 2
Frequency: 1
Odometer: 143644 km
Engine RPM: 671 rpm
04709 [0x001265]
Status bits: 1
Priority: 6
Frequency: 1
Odometer: 143644 km
Engine RPM: 671 rpm
Paramteric values: 20 96 28 10 5F 00 10 60 00 10 61 00 10 62 00 14 CB 00 10 C1 00 00
04. Power steering
No DTC found.
08. Heater and climate
No DTC found.
15. SRS15. SRS
DTCs: 1
1050368 [0x100700]
U112100: Databus missing message
CAN: 0x323 PCF_01 Timeout
Status bits: 1
Priority: 6
Frequency: 1
Odometer: 143644 km
16. Steering column
No DTC found.
17. Dashboard17. Dashboard
DTCs: 3
16776960 [0xFFFF00]
ACC_02_FR keine Kommunikation
Status bits: 1
Priority: 6
Frequency: 1
Odometer: 143644 km
16776961 [0xFFFF01]
ACC_04_FR keine Kommunikation
Status bits: 1
Priority: 6
Frequency: 1
Odometer: 143644 km
16776980 [0xFFFF14]
VZE_01 keine Kommunikation
Status bits: 1
Priority: 6
Frequency: 1
Odometer: 143644 km
28. Climate Control Panel28. Climate Control Panel
DTCs: 4
00025 [0x000019] Archive (inactive)
B10D322: Left rear upper body vent motor, Upper limit exceeded
Stellmotor für Klappe MA Fond li. oberer Grenzwert überschritten
Status bits: 1
Priority: 3
Frequency: 1
Unlearning index: 105
Odometer: 143675 km
Date, time: 2023.10.12 17:15:57
Paramteric values: 02 86 0B FD 26 09 89 26 A6 2D B5 2D B5 2C B0 27 10
Status: Confirmed
00026 [0x00001A] Archive (inactive)
B10D321: Left rear upper body vent motor, Lower limit not reached
Stellmotor für Klappe MA Fond li. unterer Grenzwert unterschritten
Status bits: 1
Priority: 3
Frequency: 1
Odometer: 143644 km
Date, time: 2023.10.12 15:19:50
Paramteric values: 02 86 0E 21 26 09 9A 26 A6 26 79 26 79 2C B0 27 10
Status: Confirmed
00033 [0x000021] Archive (inactive)
B10D422: Right rear upper body vent motor, Upper limit exceeded
Stellmotor für Klappe MA Fond re. oberer Grenzwert überschritten
Status bits: 1
Priority: 3
Frequency: 3
Odometer: 143644 km
Date, time: 2023.10.12 15:19:52
Paramteric values: 02 86 0E 21 26 09 9B 26 A7 2D B5 2D B5 2D 51 27 10
Status: Confirmed
00034 [0x000022]
B10D421: Right rear upper body vent motor, Lower limit not reached
Stellmotor für Klappe MA Fond re. unterer Grenzwert unterschritten
Status bits: 1
Priority: 3
Frequency: 2
Odometer: 143644 km
Date, time: 2023.10.12 15:12:51
Paramteric values: 02 86 0D FB 26 09 96 26 A7 26 79 26 79 2D 51 27 10
34. Ride height control system34. Ride height control system
DTCs: 1
00002 [0x000002]
Funktionseinschränkung wegen fehlender Botschaft
Status bits: 1
Priority: 6
Frequency: 1
Odometer: 143644 km
Date, time: 2023.10.12 15:12:43
3C. Lane change assistant
No DTC found.
42. Driver door electronic equipment
No DTC found.
44. Power steering
No DTC found.
46. Central comfort systems module (VW TP2.0)
No DTC found.
47. Acoustic system47. Acoustic system
DTCs: 1
03405 [0x0D4D]
Status: Pending fault present, Pending fault present during this driving cycle, Test is inhibited by other DTC, Validated and stored in non volatile memory, Validated fault present at time of request
52. Front passenger door electronics
No DTC found.
53. Parking brake53. Parking brake
DTCs: 1
327936 [0x050100]
FC_ACC_05_MESSAGE_TIMEOUT
Status bits: 1
Priority: 6
Frequency: 1
Odometer: 143644 km
Engine RPM: 9109 rpm
Vehicle speed: 1 km/h
Engine coolant temperature: 195.8 ?
Barometric pressure: 5 kPa
Klemme 30 voltage: 4
55. Headlights corrector
No DTC found.
56. Head unit (MMI) (VW TP2.0)56. Head unit (MMI) (VW TP2.0)
DTCs: 1
02983 [0x0BA7]
Connection of resistance transformer 1 and glass antenna; Connection between impedance converter 1 and window antenna
5F. Electronic Information System 15F. Electronic Information System 1
DTCs: 1
03157 [0x0C55]
Status: Validated and stored in non volatile memory, Validated fault present at time of request
62. Rear left door electoronics (VW TP2.0)
No DTC found.
6C. Rear view camera system var.1
No DTC found.
6D. Tailgate/Boot lid
No DTC found.
72. Rear right door electronics (VW TP2.0)
No DTC found.
82. HUD (UDS)82. HUD (UDS)
DTCs: 3
16776960 [0xFFFF00]
Status bits: 1
Priority: 6
Frequency: 1
Odometer: 143644 km
16776961 [0xFFFF01]
ACC_04 keine Kommunikation
Status bits: 1
Priority: 6
Frequency: 1
Odometer: 143644 km
16776970 [0xFFFF0A]
VZE_01_ keine Kommunikation
Status bits: 1
Priority: 6
Frequency: 1
Odometer: 143644 km
84. Night vision (UDS)
No DTC found.
A9. Structure-Borne Sound Actuator / Exhaust flaps (UDS)
No DTC found.
BA. Subframe mount (UDS)BA. Subframe mount (UDS)
DTCs: 1
01294 [0x00050E]
C113107: Actuator 1 for assembly mounting, mechanical malfunction
FC_VCA_ActuatorRight_Mechanical_Fault
Status bits: 1
Priority: 1
Frequency: 1
Odometer: 143644 km
Date, time: 2023.10.12 15:12:45
Seht ihr irgendwas was ich nicht seh?
Danke im Voraus fuer eure Hilfe!
5 Antworten
Sieht nach ein Kabel Problem aus oder ACC Sensor kaputt, schaue dir mal die Verkabelung an, ist die Sicherung heil?
Die Steckverbindungen von den beiden Radarsensoren prüfen die könnten durch eine Undichtigkeit korrodiert sein.
Ja die Sicherung ist ganz. 10A waren's Strom laeuft also prima durch.
Ich hab echt die Befuerchtung dass der Master also der rechte Sensor durch ist...
Witzigerweise habe ich VZE ueber VCDS reincodiert und das ist mir direkt um die Ohren geflogen wegen ACC.
