Battery draining Passat 3c (2006)
I have passat 3c (2006y) and I have problem with battery,I have parasitic curent (1.3A)! When the car goes to sleep mode current goes to 0.2A then clicking noise is coming from comfort module behind passenger dash! I try to disconect Alarm Horn, doors cables but situation is same. If car stays more than two days battery is out !
Can someone help me!
7 Antworten
Any retrofittings done? A Radio maybe? VCDS Vehicle Scan?
No everything in car is original including car radio RNS 300. Also there is no errors reporting by VCDS. |Only error is thermal protection active on doors but I disconected all doors and situation is same?
Anybody...
0.2 is definitely too much. As I remember 0.001 - 0.003A is a good value.
I would do the following:
Connect your ammeter and take the fuses out one after another. If the drain value falls to a normal one you know the circuit you have to inspect.
There are many possible reasons for higher draining, e.g. corroded contacts, damaged cables, internal short circuit...
If you can't find anything there you could also check fuses in the fuse box in the engine bay.
Still no luck? Try to disconnect wiring from starter and generator.
This is my VCDS log:
Friday,04,January,2013,19:32:46:10074
VCDS Version: Release 10.6.4
Data version: 20110418
Chassis Type: 3C0
Scan: 01 03 08 09 15 16 17 19 25 37 42 44 46 52 53 56 62 72 77 7D
VIN: WVWZZZ3CZ7P02XXXX Mileage: 207740km/129083miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
37-Navigation -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: Malfunction 0010
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: Malfunction 0010
53-Parking Brake -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
62-Door, Rear Left -- Status: Malfunction 0010
72-Door, Rear Right -- Status: Malfunction 0010
77-Telephone -- Status: OK 0000
7D-Aux. Heat -- Status: OK 0000
Address 01: Engine Labels: Redir Fail!
Part No SW: 03G 906 021 NK HW: 03G 906 021 AB
Component: R4 2,0L EDC G000SG 9354
Revision: --H02--- Serial number: VWZCZ000000000
Coding: 0000072
Shop #: WSC 00028 028 00001
VCID: 75E5E5E76551
No fault code found.
Readiness: 0 0 0 0 0
Address 03: ABS Brakes Labels: 3C0-614-095-C2.lbl
Part No SW: 3C0 614 095 P HW: 3C0 614 095 P
Component: ESP 440 C2 H015 0004
Revision: H015 Serial number: 0667610112
Coding: 0013602
VCID: 2F69178FC78D
Address 08: Auto HVAC Labels: 3C0-907-044.lbl
Part No SW: 3C0 907 044 AH HW: 3C0 907 044 AH
Component: ClimatronicPQ46 050 0505
Revision: 00050005 Serial number: 00000000000000
Shop #: WSC 00000 000 00000
VCID: 67D9BFAF2FFD
Address 09: Cent. Elect. Labels: 3C0-937-049-23-H.lbl
Part No SW: 3C0 937 049 J HW: 3C0 937 049 J
Component: Bordnetz-SG H37 1301
Revision: 00H37000 Serial number: 00000004193670
Coding: E1808F0700041A00000A00000F00000000095D435C0000
VCID: 306B14F3DAB3
Part No: 3C1 955 119
Component: Wischer VW461 012 0503
Coding: 00063445
Shop #: WSC 00028
Part No: 1K0 955 559 AE
Component: RLS 140606 014 1201
Coding: 00208933
Shop #: WSC 00028
Address 15: Airbags Labels: 3C0-909-605.lbl
Part No SW: 3C0 909 605 J HW: 3C0 909 605 J
Component: 04 AIRBAG VW8 029 2521
Revision: 09029000 Serial number: 003A2PBKBZD1
Coding: 0012340
VCID: 2D550D87CD81
Address 16: Steering wheel Labels: 3C0-953-549-SW20.lbl
Part No SW: 3C0 953 549 A HW: 3C0 953 549 A
Component: Lenks?ulenmodul 005 0010
Revision: 00005000 Serial number: 3C5953507C
Coding: 0000013
VCID: 2A5F069BFC6F
Address 17: Instruments Labels: 3C0-920-xxx-17.lbl
Part No SW: 3C0 920 871 X HW: 3C0 920 871 X
Component: KOMBIINSTRUMENT VD1 1614
Revision: V0007000 Serial number: 00000000000000
Coding: 0005105
Shop #: WSC 11111 111 11111
VCID: 397D29D709C9
Address 19: CAN Gateway Labels: 3C0-907-530.lbl
Part No SW: 3C0 907 530 C HW: 3C0 907 951 A
Component: Gateway 007 0040
Revision: 00007000 Serial number: 0700C0660605F1
Coding: 3DFD2C44C61002
VCID: 214DE1B78159
Address 25: Immobilizer Labels: 3C0-959-433-25.clb
Part No SW: 3C0 959 433 R HW: 3C0 959 433 R
Component: IMMO 042 0383
Revision: 00042000 Serial number: VWZCZ000000000
Shop #: WSC 131071 1023 2097151
VCID: 397D29D709C9
Part No: 3C0 905 861 F
Component: ELV 026 0380
3C0905861F ELV 026 0380
Address 37: Navigation Labels: None
Part No SW: 1K0 035 191 D HW: 1K0 035 191 D
Component: J401 0111
Revision: 00015000 Serial number: VWZ1Z2F6278085
Coding: 0043400
VCID: 2341EBBF9B45
1 Fault Found:
00003 - Control Module
014 - Defective
Freeze Frame:
Fault Status: 00000001
Fault Priority: 3
Fault Frequency: 1
Reset counter: 72
Mileage: 207571 km
Time Indication: 0
Date: 2012.12.09
Time: 00:48:19
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN3.lbl
Part No SW: 1K0 959 701 P HW: 1K0 959 793 L
Component: J386 TUER-SG FT 1123
Revision: 12006001 Serial number: 00000044868622
Coding: 0000181
VCID: 3B7133DF03F5
1 Fault Found:
01034 - Electric Window Thermal Protection Active; Driver
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 7
Fault Frequency: 254
Reset counter: 130
Mileage: 207727 km
Time Indication: 0
Date: 2013.01.04
Time: 00:30:53
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K1 909 144 L
Component: EPS_ZFLS Kl.135 H07 1806
VCID: 346318E32EAB
Address 46: Central Conv. Labels: 3C0-959-433-46.clb
Component: KSG PQ46 ELV 042 0472
Coding: 00910A0001860E7630049C1F70084F0E507C00
VCID: 397D29D709C9
Component: Sounder No Answer
Component: NGS n.mounted
Component: IRUE n.mounted
1 Fault Found:
01134 - Alarm Horn (H12)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 4
Fault Frequency: 1
Reset counter: 90
Mileage: 207727 km
Time Indication: 0
Date: 2013.01.03
Time: 23:39:25
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl
Part No SW: 1K0 959 702 P HW: 1K0 959 792 L
Component: J387 TUER-SG BT 1123
Revision: 12006001 Serial number: 00000047268622
Coding: 0000180
VCID: 3C7330C306FB
1 Fault Found:
01035 - Electric Window Thermal Protection Active; Passenger
Freeze Frame:
Fault Priority: 7
Reset counter: 130
Mileage: 207727 km
Time Indication: 0
Date: 2013.01.04
Time: 00:31:01
Address 53: Parking Brake Labels: 3C0-907-801-53.lbl
Part No SW: 3C0 907 801 B HW: 3C0 907 801 B
Component: EPB VC8HC001 013 0001
Revision: 013
Coding: 0000011
VCID: 214DE1B78159
Address 56: Radio Labels: None
Component: R 0111
Coding: 0043400
VCID: 2341EBBF9B45
1 Fault Found:
014 - Defective
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 72
Mileage: 207571 km
Time Indication: 0
Date: 2012.12.09
Time: 00:48:19
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN3.lbl
Part No SW: 1K0 959 703 P HW: 1K0 959 795 G
Component: J388 TUER-SG HL 1113
Revision: 11004001 Serial number: 00000000227921
Coding: 0000144
VCID: 3D753DC71DE1
1 Fault Found:
01036 - Electric Window Thermal Protection Active; Rear Left
Freeze Frame:
Fault Priority: 7
Reset counter: 130
Mileage: 207727 km
Time Indication: 0
Date: 2013.01.04
Time: 00:47:33
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN3.lbl
Part No SW: 1K0 959 704 P HW: 1K0 959 794 G
Component: J389 TUER-SG HR 1113
Revision: 11004001 Serial number: 00000000228772
Coding: 0000144
VCID: 3E773ACB10E7
1 Fault Found:
01037 - Electric Window Thermal Protection Active; Rear Right
Freeze Frame:
Fault Priority: 7
Reset counter: 130
Mileage: 207727 km
Time Indication: 0
Date: 2013.01.04
Time: 00:38:04
Address 77: Telephone Labels: 3C0-035-729.lbl
Part No SW: 3C0 035 729 E HW: 3C0 035 729 E
Component: Telefon 6009
Revision: 00009000 Serial number: 0000000744765
Coding: 0016043
VCID: 2545F5A79571
Address 7D: Aux. Heat Labels: 1K0-963-235.lbl
Part No SW: 1K0 963 235 E HW: 1K0 963 235 E
Component: PTC-Element 0404
Revision: 00800000 Serial number:
VCID: 2D550D87CD81
End ---------------------------------------------------------------------
I think I found problem for my car which is drain battery. Yesterday I notice that all four blinkers was on, alarm horn was not activated but it is faulty (VCDS says it is open circuit) and driver door was detected open in MFD. After I deactivated alarm with remote, MFD still showing open left door even it was closed and then suddenly after 2-3 min. in MFD door was closed. Car is trying to go in sleep mode, current clamp is showing value between 0.7 and 0.1 relay click behind passenger dash and then amp goes again in 0.7A. But even I disconected driver door cable situation is same. If car is not locked (all doors closed) current is 0.6A and no relay clicking no current fluctuation.
I want to know does CAN Gatewey will shut off all modules even some module is missing (Lets say driver door or radio) or will try to connect again (loop).
Hi! I have exactly the same problem with my 2006 Passat, except that it is saying that passenger door is open.
I know this is a bit of an old thread, but I will try nevertheless.
Did you get this fixed? Mind sharing what the problem was? I would REALLY appreciate it!
I have now had the horn replaced as well as the passenger side door latch module, both did nothing to fix the issue. Now the shop is saying I should replace my driver door handle with the keyless entry contacts for €€€. Somehow I very much doubt that is the issue.
Problem was fixed, it was door control module, there was a big cracked soldering joint on on wire from connector! BTW this was common problem with passat b6 and golf 5 !
