  4. Audi
  5. A4
  6. A4 B8
  7. Esp, motorkontrollleuchte, hilfe
Audi A4 B8/8K
Hallo :) Vielleicht kann jemand helfen?
LMM wurde schon gewechselt
VCDS Version: Release 12.12.0 Data version: 20130910 Tuesday,20,August,2019,16:12:10:62939 Chassis Type: 8K (8T0) Scan: 01 03 05 08 09 15 16 17 19 42 46 52 53 56 62 72 VIN: WAUZZZ8K48N026247 Mileage: 140040km/87016miles 01-Engine -- Status: Malfunction 0010 03-ABS Brakes -- Status: Malfunction 0010 04-Steering Angle -- Status: OK 0000 05-Acc/Start Auth. -- Status: OK 0000 08-Auto HVAC -- Status: OK 0000 09-Cent. Elect. -- Status: OK 0000 15-Airbags -- Status: OK 0000 16-Steering wheel -- Status: OK 0000 17-Instruments -- Status: Malfunction 0010 19-CAN Gateway -- Status: OK 0000 42-Door Elect, Driver -- Status: Malfunction 0010 46-Central Conv. -- Status: OK 0000 52-Door Elect, Pass. -- Status: OK 0000 53-Parking Brake -- Status: Malfunction 0010 56-Radio -- Status: OK 0000 62-Door, Rear Left -- Status: OK 0000 72-Door, Rear Right -- Status: OK 0000 ------------------------------------------------------------------------------- Address 01: Engine (------CABB) Labels: 06H-907-115-CAB.clb Part No SW: 8K1 907 115 A HW: 8K1 907 115 Component: 1.8l R4/4V TF H07 0004 Revision: A5H07--- Coding: 0104000318070020 Shop #: WSC 02145 785 00200 ASAM Dataset: EV_ECM18TFS8K1907115A A01005 ROD: EV_ECM18TFS8K1907115A.rod VCID: 2C57E23B47FEEC7E18B-8079 2 Faults Found: 5667 - Mass Air Flow Sensor (G70) P0101 00 [101] - Implausible Signal Not Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 1 Mileage: 139931 km Date: 2008.02.10 Time: 11:02:10 2999 - Pressure Drop between Turbo and Throttle Valve (check D.V.!) P1297 00 [101] - - Not Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 1 Mileage: 139931 km Date: 2008.02.10 Time: 11:02:07 Readiness: 0010 0101 ------------------------------------------------------------------------------- Address 03: ABS Brakes (J104) Labels: 8K0-907-379.clb Part No SW: 8K0 907 379 P HW: 8K0 907 379 P Component: ESP8 front H04 0180 Revision: -------- Serial number: -------------- Coding: 030500 Shop #: WSC 02399 823 56573 VCID: 4683B093F152362EEEF-8013 2 Faults Found: 01314 - Engine Control Module 013 - Check DTC Memory Freeze Frame: Fault Status: 01101101 Fault Priority: 6 Fault Frequency: 5 Reset counter: 48 Mileage: 139931 km Time Indication: 0 Date: 2008.02.10 Time: 11:02:08 Freeze Frame: Hex Value: 0x3400 Hex Value: 0x4002 Hex Value: 0x1209 Hex Value: 0x46AF Hex Value: 0x00FF 00473 - Control Module for Elect. Park/Hand Brake (J540) 013 - Check DTC Memory Freeze Frame: Fault Status: 01101101 Fault Priority: 6 Fault Frequency: 1 Reset counter: 48 Mileage: 139988 km Time Indication: 0 Date: 2008.02.10 Time: 11:31:40 Freeze Frame: Hex Value: 0x0040 Hex Value: 0x2786 Hex Value: 0x1213 Hex Value: 0x029E Hex Value: 0x00FF ------------------------------------------------------------------------------- Address 05: Acc/Start Auth. (J393) Labels: 8K0-907-064-05.clb Part No SW: 8K0 907 064 A HW: 8K0 907 064 A Component: BCM2 1.1 H70 0134 Revision: 00002001 Coding: 030100 Shop #: WSC 02399 823 56573 VCID: 2E53E83379E29E6E36F-807B Subsystem 1 - Part No SW: 8T0 959 754 D HW: 8T0 959 754 D Component: FBSAUDIB8 IDG H37 0060 Subsystem 2 - Part No SW: 8K0 905 852 D HW: 8K0 905 852 D Component: ELVAUDIB8 H35 0039 No fault code found. ------------------------------------------------------------------------------- Address 08: Auto HVAC (J255) Labels: Redir Fail! Part No SW: 8T1 820 043 N HW: 8T1 820 043 N Component: KLIMA 1 ZONE H05 0120 Revision: A0000000 Serial number: 0117.04.080284 Coding: 64000000 Shop #: WSC 02399 823 56573 VCID: 3C77D27BBF9E7CFE88B-8069 No fault code found. ------------------------------------------------------------------------------- Address 09: Cent. Elect. (J519) Labels: 8K0-907-063.clb Part No SW: 8K0 907 063 HW: 8K0 907 063 Component: BCM1 1.0 H21 0253 Revision: 01021001 Serial number: 00000000024993 Coding: 690080B10014A7000001000000005F5F4014020800000101000000 Shop #: WSC 02399 823 56573 VCID: ECD7A23B0F7EAC7ED8B-80B9 Subsystem 1 - Part No SW: 8K1 955 119 HW: 8T1 955 119 Labels: 1KX-955-119.CLB Component: WWS 190408 H06 0060 Coding: 00FD11 Subsystem 2 - Part No SW: 8K0 955 559 HW: 8K0 955 559 Labels: 8K0-955-559.CLB Component: RLS H04 0003 Coding: 025028 Subsystem 3 - Part No SW: 8K0 941 531 C HW: 8K0 941 531 C Component: E1 - LDS H07 0070 No fault code found. ------------------------------------------------------------------------------- Address 15: Airbags (J234) Labels: 8K0-959-655.clb Part No SW: 8K0 959 655 B HW: 8K0 959 655 B Component: AirbagVW-AU10 H26 0410 Serial number: 0038JD14SARR Coding: 30343434363030303030554A304C384B3053 Shop #: WSC 02145 785 00200 ASAM Dataset: EV_AirbaECUVWAUDI010 A02007 ROD: EV_AirbaECUVWAUDI010_AU48.rod VCID: 3C77D27BB79E7CFE88B-8069 Crash sensor for side airbag; driver side: Serial number: 6334MSME3A160E78M Crash sensor for side airbag; passenger side: Serial number: 6344MSME3A156B3ER Crash sensor for side airbag; rear driver side: Serial number: 6352QSME60470845B Crash sensor for side airbag; rear passenger side: Serial number: 6362QSME5E28442FW Crash sensor for front airbag; driver side: Serial number: 63732SME61273E795 Crash sensor for front airbag; passenger side: Serial number: 63832SME5C4C520B8 No fault code found. ------------------------------------------------------------------------------- Address 16: Steering wheel (J527) Labels: 8K0-953-568.clb Part No SW: 8K0 953 568 D HW: 8K0 953 568 D Component: Lenks.Modul H12 0013 Revision: -------- Serial number: 90315HDC0000B Coding: 000000 Shop #: WSC 02399 823 56573 VCID: 3B75D167BA907BC6811-806E No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments (J285) Labels: 8T0-920-xxx-17.clb Part No SW: 8K0 920 900 HW: 8K0 920 900 Component: KOMBIINSTR. H15 0221 Revision: 00000000 Serial number: 7VH22MJ48 Coding: 0F01080002000008000001 Shop #: WSC 02399 823 56573 VCID: E7DDDD1716988F26B59-80B2 1 Fault Found: 00003 - Control Module 005 - No or Incorrect Basic Setting / Adaptation Freeze Frame: Fault Status: 01100101 Fault Priority: 6 Fault Frequency: 1 Reset counter: 10 Mileage: 138090 km Time Indication: 0 Date: 2019.07.26 Time: 20:38:03 ------------------------------------------------------------------------------- Address 19: CAN Gateway (J533) Labels: 8T0-907-468.clb Part No SW: 8T0 907 468 H HW: 8T0 907 468 H Component: GW-BEM 5CAN H06 0091 Revision: GB102039 Serial number: 3900G084018634 Coding: 000303 Shop #: WSC 02399 823 56573 VCID: 4683B093F152362EEEF-8013 Subsystem 1 - Part No SW: 8K0 915 181 B HW: 8K0 915 181 B Component: J367-BDM H03 0150 No fault code found. ------------------------------------------------------------------------------- Address 42: Door Elect, Driver (J386) Labels: 8K0-959-793.clb Part No SW: 8K0 959 793 C HW: 8K0 959 793 A Component: TSG FA H10 0170 Revision: Serial number: 0000007077796 Coding: 011002204000410001 Shop #: WSC 02399 823 56573 VCID: 408FA68BD376181ED43-8015 1 Fault Found: 02115 - Locking Unit for Central Locking 008 - Implausible Signal - Intermittent Freeze Frame: Fault Status: 00101000 Fault Priority: 3 Fault Frequency: 1 Reset counter: 87 Mileage: 139988 km Time Indication: 0 Date: 2008.02.10 Time: 20:01:57 ------------------------------------------------------------------------------- Address 46: Central Conv. (J393) Labels: 8K0-907-064-46.clb Part No SW: 8K0 907 064 A HW: 8K0 907 064 A Component: BCM2 1.1 H70 0134 Revision: 00002001 Serial number: 0111025356 Coding: 0100062000390040013001 Shop #: WSC 02399 823 56573 VCID: 2E53E83379E29E6E36F-807B No fault code found. ------------------------------------------------------------------------------- Address 52: Door Elect, Pass. (J387) Labels: 8K0-959-792.clb Part No SW: 8K0 959 792 C HW: 8K0 959 792 A Component: TSG BF H10 0170 Revision: Serial number: 0000007038161 Coding: 011002204000410001 Shop #: WSC 02399 823 56573 VCID: 3F8DA577AE8867E6AD9-806A No fault code found. ------------------------------------------------------------------------------- Address 53: Parking Brake (J540) Labels: 8K0-907-801-V1.clb Part No SW: 8K0 907 801 D HW: 8K0 907 801 D Component: EPB Audi B8 H04 0050 Revision: 00000003 Serial number: 00000000110031 Shop #: WSC 00000 000 00000 VCID: 306FF64B63D6889E243-8065 1 Fault Found: 01314 - Engine Control Module 013 - Check DTC Memory - MIL ON Freeze Frame: Fault Status: 11101101 Fault Priority: 4 Fault Frequency: 1 Reset counter: 47 Mileage: 139931 km Time Indication: 0 Date: 2008.02.10 Time: 11:02:08 Freeze Frame: Voltage: 14.30 V Count: 58 Speed: 52.0 km/h Hex Value: 0x0260 Hex Value: 0x0004 Hex Value: 0x0101 ------------------------------------------------------------------------------- Address 56: Radio (J503) Labels: 8Tx-035-1xx-56.clb Part No SW: 8T1 035 186 B HW: 8T1 035 186 B Component: Concert3 H13 0150 Revision: 00000016 Serial number: AUZ5Z6H1051632 Coding: 05000480040101000519070000 Shop #: WSC 02399 823 56573 VCID: 3663C05381B2A6AE7EF-8063 Subsystem 1 - Part No SW: 8T0 919 603 A HW: 8T0 919 603 A Component: Display No fault code found. ------------------------------------------------------------------------------- Address 62: Door, Rear Left (J388) Labels: 8K0-959-795.clb Part No SW: 8K0 959 795 A HW: 8K0 959 795 A Component: TSG HL H06 0170 Revision: Serial number: 0000007079003 Coding: 010002204000210001 Shop #: WSC 02399 823 56573 VCID: 408FA68BD376181ED43-8015 No fault code found. ------------------------------------------------------------------------------- Address 72: Door, Rear Right (J389) Labels: 8K0-959-794.clb Part No SW: 8K0 959 794 A HW: 8K0 959 795 A Component: TSG HR H06 0170 Revision: Serial number: 0000007052919 Coding: 010002204000210001 Shop #: WSC 02399 823 56573 VCID: 3F8DA577AE8867E6AD9-806A No fault code found. End --------------------------------------------------------------
1 Antworten
kauf ein original vcds auf deutsche und kein alten china müll
dein fehler kommt vom luftmassensystem.turbo ladedruck und luftmasse stehen deshalb auch im fehlerspeicher.
