  4. BMW
  5. 3er
  6. F30, F31, F34 & F80
  7. Fehler bei Start von Ista
BMW 3er F31
Beim Start meiner Version von Ista 3.56.21 kommt nach dem entpacken und beim Versuch zu starten: failed to start ista. please make sure your ista configuration is valid
Hier meine Log File. Kann mir jemand helfen ?
2017-10-16 22:03:02 INFO [T] ISTA: [1] ConfigSettings.ConfigSettings() - called
2017-10-16 22:03:03 INFO [T] ISTA: [1] ConfigSettings.set_CurrentCulture() - set UI culture to en-GB
2017-10-16 22:03:03 INFO [T] ISTA: [1] ConfigSettings.StoreAndLogChangedValue() - Change configuration "DebugLevel" from "0" to "2" (read from "Configuration file";).
2017-10-16 22:03:03 INFO [T] ISTA: [1] ConfigSettings.StoreAndLogChangedValue() - Change configuration "BMW.Rheingold.OperationalMode" from "ISTA" to "ISTA_PLUS" (read from "Configuration file";).
2017-10-16 22:03:03 INFO [T] ISTA: [1] ConfigSettings.ConfigSettings() - OperationalMode is ISTA_PLUS
2017-10-16 22:03:03 INFO [T] ISTA: [1] ConfigSettings.StoreAndLogChangedValue() - Change configuration "BMW.Rheingold.Logging.Directory" from "" to "..\..\..\Logs" (read from "Configuration file";).
2017-10-16 22:03:03 INFO [T] ISTA: [1] App.App() - *************** *************** *************** New instance created *************** *************** ***************
2017-10-16 22:03:04 INFO [T] ISTA: [1] App.App() - **************** ***************
2017-10-16 22:03:04 INFO [T] ISTA: [1] App.App() - Operating System: Microsoft Windows XP Professional
2017-10-16 22:03:04 INFO [T] ISTA: [1] App.App() - OS Bit-Version : 32bit
2017-10-16 22:03:04 INFO [T] ISTA: [1] App.App() - Current directory: C:\Programme\Rheingold\TesterGUI\bin\Release
2017-10-16 22:03:04 INFO [T] ISTA: [1] ConfigSettings.StoreAndLogChangedValue() - Change configuration "BMW.Rheingold.ISTAGUI.BinPathModifications" from "" to "..\..\..\Ediabas\BIN" (read from "Configuration file";).
2017-10-16 22:03:04 INFO [T] ISTA: [1] App.App() - bin path modifications found: ..\..\..\Ediabas\BIN
2017-10-16 22:03:04 INFO [T] ISTA: [1] App.App() - Resulting bin path: C:\Programme\Rheingold\Ediabas\BIN;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;c:\ediabas\bin
2017-10-16 22:03:04 INFO [T] ISTA: [1] ConfigSettings.StoreAndLogChangedValue() - Change configuration "BMW.Rheingold.Logging.Log4Net.Configure" from "False" to "True" (read from "Configuration file";).
2017-10-16 22:03:04 INFO [T] ISTA: [1] App.App() - configure extendend logging features...
log4net:ERROR Unhandled exception in GetInfoForAssembly
System.TypeLoadException: Could not load type 'System.Runtime.CompilerServices.ExtensionAttribute' from assembly 'mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089'.
at System.ModuleHandle.ResolveType(RuntimeModule module, Int32 typeToken, IntPtr* typeInstArgs, Int32 typeInstCount, IntPtr* methodInstArgs, Int32 methodInstCount, ObjectHandleOnStack type)
at System.ModuleHandle.ResolveTypeHandleInternal(RuntimeModule module, Int32 typeToken, RuntimeTypeHandle[] typeInstantiationContext, RuntimeTypeHandle[] methodInstantiationContext)
at System.Reflection.RuntimeModule.ResolveType(Int32 metadataToken, Type[] genericTypeArguments, Type[] genericMethodArguments)
at System.Reflection.CustomAttribute.FilterCustomAttributeRecord(CustomAttributeRecord caRecord, MetadataImport scope, Assembly& lastAptcaOkAssembly, RuntimeModule decoratedModule, MetadataToken decoratedToken, RuntimeType attributeFilterType, Boolean mustBeInheritable, Object[] attributes, IList derivedAttributes, RuntimeType& attributeType, IRuntimeMethodInfo& ctor, Boolean& ctorHasParameters, Boolean& isVarArg)
at System.Reflection.CustomAttribute.GetCustomAttributes(RuntimeModule decoratedModule, Int32 decoratedMetadataToken, Int32 pcaCount, RuntimeType attributeFilterType, Boolean mustBeInheritable, IList derivedAttributes, Boolean isDecoratedTargetSecurityTransparent)
at System.Reflection.CustomAttribute.GetCustomAttributes(RuntimeAssembly assembly, RuntimeType caType)
at System.Reflection.RuntimeAssembly.GetCustomAttributes(Type attributeType, Boolean inherit)
at System.Attribute.GetCustomAttributes(Assembly element, Type attributeType, Boolean inherit)
at log4net.Core.DefaultRepositorySelector.GetInfoForAssembly(Assembly assembly, String& repositoryName, Type& repositoryType)
log4net:ERROR Failed to configure repository [log4net-default-repository] from assembly attributes.
at log4net.Core.DefaultRepositorySelector.LoadAliases(Assembly assembly, ILoggerRepository repository)
at log4net.Core.DefaultRepositorySelector.CreateRepository(Assembly repositoryAssembly, Type repositoryType, String repositoryName, Boolean readAssemblyAttributes)
ISTAGUI.exe: 2017-10-16 22:03:04,734 [1] INFO ISTAGUI.exe [(null)] - Log4Net initial log statement
2017-10-16 22:03:05 INFO [T] ISTA: [1] App.App() - configure extendend logging features finished
2017-10-16 22:03:05 ERROR [T] ISTA: [1] App.App() - Failed to start ISTA: System.TypeLoadException: Method 'GetPrintCommand' in type 'BMW.Rheingold.ISTAGUI.ApplicationController' from assembly 'ISTAGUI, Version=3.56.21.0, Culture=neutral, PublicKeyToken=6505efbdc3e5f324' does not have an implementation.
at BMW.Rheingold.ISTAGUI.Bootstrapper.Initialize()
at BMW.Rheingold.ISTAGUI.App..ctor()
Bei dem blauen ist noch alles in Ordnung. Die Roten Felder sind die Fehler.
Mein System Windows Xp Professional , Net Framework 4.0 , Visual C++ 2015
29 Antworten
Als Administrator gestartet?
Den RegistryFix ausgeführt?
Ja alles gemacht , habe rausgefunden das mind Net Framework 4.5 installiert sein muss und das geht nicht mit XP.
Das heißt 3.56.21 läuft nicht auf XP, deshalb der Log fehler.
Benutze dann weiterhin 3.47.10 ;) Werde die psdzdata noch auf 62.5 updaten und gut ist :) Für meine zwecke reicht das.
Habe jetzt Inpa 5.50 , NCS 4.0.1 , Inpa Fxx , Esys und Ista-D 3.47.10 , Tis und ETK auf XP
ich möchte ISTA-D 4.09.13 installieren und bekomme beim Starten immer den Fehler "Failed to start ISTA. Please make sure your ISTA conifiguration is valid...."
Habe schon alles mehrmals versucht aber es klappt nicht. Ganz am Anfang hat es kurz funktioniert und dann plötzlich nicht mehr.
In der Log steht folgendes
2018-01-17 08:30:40 WARNING [T] ISTA: [1] DatabaseProvider.DatabaseProviderNone.Instance() - Using DatabaseProviderNone!
2018-01-17 08:30:40 INFO [T] ISTA: [1] ConfigSettings.StoreAndLogChangedValue() - Change configuration "BMW.Rheingold.Clamp30.Voltage.Min.Error.Pb" from "" to "9.95" (read from "Configuration file";).
2018-01-17 08:30:40 INFO [T] ISTA: [1] ConfigSettings.StoreAndLogChangedValue() - Change configuration "BMW.Rheingold.Clamp30.Voltage.Min.Warning.Pb" from "" to "10" (read from "Configuration file";).
2018-01-17 08:30:40 INFO [T] ISTA: [1] ConfigSettings.StoreAndLogChangedValue() - Change configuration "BMW.Rheingold.Clamp30.Voltage.Max.Warning.Pb" from "" to "14.85" (read from "Configuration file";).
2018-01-17 08:30:40 INFO [T] ISTA: [1] ConfigSettings.StoreAndLogChangedValue() - Change configuration "BMW.Rheingold.Clamp30.Voltage.Max.Error.Pb" from "" to "15.55" (read from "Configuration file";).
2018-01-17 08:30:40 ERROR [T] ISTA: [1] ServiceLocator.GetService<T>() - No service registered for type "BMW.Rheingold.ISTAGUI.Navigation.INavigationServiceGui". Using default instead.
-Rheingold liegt bei mir auf C: und SQLiteDBs ist dort enpackt.
-PSdZ ist in dem Ordner entpackt.
-beide ISTA-D Reg Fix xXX wurden mehrfach ausgeführt
-Ediabas 7.3.0 ist auch installiert
-die Hosts Files wurden auch zurückgesetzt
-die Registrierdatein wurden von mir manuell gelöscht, um dann nochmal die ISTA-D Reg Fix x64 Datei auszuführen
-RCleanerV4.4 wird als Admin ausgeführt
-Habe nur die Windows Firewall die auch ausgeschaltet ist
-ich habe ein All-in Paket für vcredist und net Framework installiert. (hab auch einmal versucht alles manuell zu installieren, danach hat es auch nicht funktioniert)
In der Log bricht das Programm nach diesem Eintrag ab: 2018-01-17 08:30:40 ERROR [T] ISTA: [1] ServiceLocator.GetService<T>() - No service registered for type "BMW.Rheingold.ISTAGUI.Navigation.INavigationServiceGui". Using default instead.
Was bedeutet der und wie kann ich das Lösen?
Matse
@izzo90 schrieb am 17. Januar 2018 um 13:53:03 Uhr:
Matse
Das Programm selbst auch als Adminstrator gestartet?
Wenn du die ISTAGUI.exe im Ordner ...:\Rheingold\TesterGUI\bin\Release suchst, und dann mit Rechtsklick auf Eigenschaften gehst, gibt es dort dann das Kästchen "Zulassen"?
Zulassen
@atzebmw,
ja das Programm führe ich als Administrator aus.
Das Kästchen gibt es bei mir nicht. :(
Ist es dann egal oder muss ich es dann irgendwo anders einstellen?
Bei mir genau der gleiche Fehler. Alles installiert und schon seit 2 Tagen am löschen, neuinstallien, Registry.... Bin auch über jede Hilfe dankbar :-)
@Gandalfo_e46, ich kann dir ja mal kurz sagen was ich gemacht habe.
- All-in one Runtime installiert (da war ich mir sicher, dass alles richtig installiert worden ist)
- die hosts Datei zurückgesetzt
- als Admin ausgeführt
- neuentpackt
- neugeladen.
Wenn du dir die Log Datei anschaust (im Ordner C:/Rheingold/Logs) was steht da geschrieben?
@izzo90
Geht's denn jetzt bei dir?
Sorry, ich dachte ich hatte gestern noch deine Frage beantwortet.
Also wenn es das Kästchen "Zulassen" nicht gibt, ist das ein gutes Zeichen, weil dann Windows diese Datei nicht blockiert.
Nein, leider nicht.
Hast du noch mehr Ideen?
Ja, mir ist noch eingefallen, wurden denn die vcredist.exe und die vs90_piaredist.exe installiert?
Für die vcredist habe ich ein All-in one Paket installiert. Ich habe die auch dreimal manuell installiert, funktioniert auch nicht.
Das vs90_piaredist.exe startet die Installation und verschwindet dann nach kurzer Zeit wieder. Es kommt da keine Bestätigung, das es installiert worden ist. Ist das richtig?
@izzo90 schrieb am 18. Januar 2018 um 16:15:36 Uhr:
Ja, gerade nochmal getestet. Ist richtig.
Mehr fällt mir nicht mehr ein, außer die Frage, ob du es denn evtl. nochmal von woanders downloaden möchtest/würdest?
Dann könnte ich dir mal meinen Link zur Verfügung stellen.
Hier meine Fehlerliste:
2018-01-18 16:44:20 ERROR [T] ISTA: [1] IstaProcessStarter.Start() - Failed to start ISTA operation. Reason: "System.Data.SQLite.SQLiteException (0x80004005): database disk image is malformed
2018-01-18 16:44:20 ERROR [T] ISTA: [1] App.Init() - Failed to start ISTA: BMW.Rheingold.CoreFramework.WcfCommon.IstaProcessStartException: Failed to start ISTA operation. Reason: "System.Data.SQLite.SQLiteException (0x80004005): database disk image is malformed
2018-01-18 16:44:28 ERROR [T] ISTA: [1] LicenseManager.get_LicenseInfo() - licString was null; no license verification from License.xml possible
2018-01-18 16:44:28 ERROR [T] ISTA: [1] LicenseManager.verifyLicense() - LicInfo was null
2018-01-18 16:44:28 ERROR [T] ISTA: [1] LicenseManager.verifyLicense() - failed with exception: BMW.Rheingold.CoreFramework.LicenseVerificationException: Error --- The session could not be verified against the online portal. Check the network connection and the validity of the portal session.
bei BMW.Rheingold.CoreFramework.LicenseManager.VerifyLicense()
2018-01-18 16:44:34 ERROR [T] ISTA: [1] DatabaseProviderFactory.LoadAssembly() - failed with exception: System.Reflection.TargetInvocationException: Exception has been thrown by the target of an invocation. ---> System.Data.SQLite.SQLiteException: database disk image is malformed
2018-01-18 16:44:35 WARNING [T] ISTA: [1] DatabaseProvider.DatabaseProviderNone.Instance() - Using DatabaseProviderNone!
2018-01-18 16:44:35 INFO [T] ISTA: [1] ConfigSettings.StoreAndLogChangedValue() - Change configuration "BMW.Rheingold.Clamp30.Voltage.Min.Error.Pb" from "" to "9.95" (read from "Configuration file";).
2018-01-18 16:44:35 INFO [T] ISTA: [1] ConfigSettings.StoreAndLogChangedValue() - Change configuration "BMW.Rheingold.Clamp30.Voltage.Min.Warning.Pb" from "" to "10" (read from "Configuration file";).
2018-01-18 16:44:35 INFO [T] ISTA: [1] ConfigSettings.StoreAndLogChangedValue() - Change configuration "BMW.Rheingold.Clamp30.Voltage.Max.Warning.Pb" from "" to "14.85" (read from "Configuration file";).
2018-01-18 16:44:35 INFO [T] ISTA: [1] ConfigSettings.StoreAndLogChangedValue() - Change configuration "BMW.Rheingold.Clamp30.Voltage.Max.Error.Pb" from "" to "15.55" (read from "Configuration file";).
2018-01-18 16:44:35 ERROR [T] ISTA: [1] ServiceLocator.GetService<T>() - No service registered for type "BMW.Rheingold.ISTAGUI.Navigation.INavigationServiceGui". Using default instead.
Selbst wenn die ersten Fehler weg wären, hätte ich ja noch die gleichen Fehler wie du...
Irgendwas muss an der Datei nicht stimmen.
Ja, du hast genau den gleichen Fehler wie ich.
Ich hatte schon die Version 4.07, damit hat es auch nicht funktioniert. Dann 4.08.13, da kam auch der gleiche Fehler und jetzt 4.09.13.
Das komische ist, dass Ista-P läuft.
Noch eine Frage @atzebmw, in der Anleitung steht Ediabas.exe installieren, ich habe aber nur patched_Ediabas_7.3.0.msi. Ist dabei die patched_Ediabas_7.3.0.msi gemeint?
  4. BMW
  5. 3er
