Komplexe frontscheibe: beheizt + AKP + HUD
Dear forum-members,
At the moment I have a new W213 on order with (amongst others) the options/SA's
- head up display
- Akustik-komfort paket
- beheizte Frontscheibe
Now I wonder how all this works together, because
- the head up display needs a special "Folie"
- in the Akustik-komfort paket is included that the front windscreen has "Akustikfolie" and "infrarot-absorbierender Folie"
- the "beheizte Frontscheibe" also works with special layers/foils
All these foils in just one windscreen?
It is possible to order all these options together, so probably it is not a technical problem. Maybe that is because they just leave out one (ore more) foils from the AKP if you order it together with the heated windscreen?
I think they do that with the C-class: the option "Akustikglas" is cheaper if you order it together with head up display. Probably because in that case they leave out the "Akustikfolie" of the front windcreen in the C-class....
Perhaps there are forum-members who have the mentioned combination of options and can tell more about this?
Thanks in advance for your response!
22 Antworten
I have all three options and it works fine (S213, 807).
@E-Doc schrieb am 1. August 2018 um 19:50:10 Uhr:
And you're sure that your front windscreen has the "Akustik folie"?
IIRC the windscreen is not "acoustic" but this is not really noticable since the foil for the HUD is partly thicker anyway and the windscreen is always a double glass
@Haagpost schrieb am 1. August 2018 um 20:11:54 Uhr:
I have all three options and it works fine (S213, 807).And you're sure that your front windscreen has the "Akustik folie"?
Yes, it has. The car has original „AKP“. Only the rear window is „normal“.
Can not really imagine that there is more than one foil between....
@nicoahlmann schrieb am 2. August 2018 um 00:50:20 Uhr:
That was my idea also. So it would be obvious that there is only one foil, namely the foil for the HUD as umbertones stated. The question then remains if this makes the AKP less effective....
No, it does not. You do not hear the difference because the HUD foil is shaped differently which has a similar effect.
Dieses Thema beschäftigt mich nog immer, es fasziniert mich. Also ging ich weiter auf der Suche und erfand mit dem MB-EPC folgendes.
Es gibt in Leitfaden fünf Sorten Windschutzscheiben (für Europa)
06 01 - HUD
09 01 - AKP oder AKP + HUD
82 00 - Beheitzt oder Beheitzt + AKP
83 00 - Beheitzt + HUD oder Beheitzt + HUD + AKP
33 01 - Standard (mit mit für dieses Thema nicht relevante varianten für Kameras, Tv-tuner usw. 34 01 / 35 01 / 07 01)
Das bedeutet also dass die akustik Folie der AKP auch geeignet ist für das HUD. Ich war davon überrascht weil ich immer gedacht habe dass es andersherum war. Die zweite Überraschung war dass bei AKP die gleiche beheitzte Scheibe verbaut wird als ohne AKP. In kombination mit HUD gibt es allerdings ein separate beheitzte Variante aber auch bei diese Scheibe ist es egal ob AKP ist gewählt.
Fazit: mit HUD gibt es akustik Folie und mit ein beheitzte Frontscheibe nicht.
* Entschuldigung für eventuelle Sprachfehler, dieser Text wurde mit Google übersetzt
Eine Frage zu Deiner tollen Aufstellung:
Die 83 00 gibt es nicht mit SA TV-Tuner?
Ich habe HUD. Möchte AKP und möglichst TV-Tuner (die Antennen-Drähte in der Scheibe) nachrüsten... beim nächsten Steinschlag
Hat jemand die Version ab Werk und kann mir die Windschutzscheiben-Nummer geben/oder die Fahrgestellnummer
Vielen Dank vorab
Peter
@PeterHB70 schrieb am 7. Oktober 2018 um 15:19:12 Uhr:
Nein die Kombination beheizt mit TV-tuner kann nicht.
Die Teilenummer für die Scheibe mit TV-tuner oder TV-tuner + HUD ist A 213 670 07 01
Es ist mir nicht ganz klar wie das in Kombination mit AKP sein wird, es sieht so aus dass du dann A 213 670 09 01 brauchst. Da bin ich mir aber nicht sicher.
@Haagpost
Hast Du auch eine Teilenummer für AKP Scheibe ohne HUD (und ohne TV) aber mit Stereokamera und Regensensor? Gibt es Unterschiede bei eingebautem SSD? Aktuell brauch ich zwar keine Scheibe, aber nach dem Winter fliegen gerne mal die Splitkörner.
@SignumFan schrieb am 8. Oktober 2018 um 14:53:05 Uhr:
Die AKP-Scheibe für alle Varianten ist A 213 670 09 01
(aber bei Bestellung immer überprüfen lassen, weil ich kein Experte bin ;-)
Mal eine andere Frage zum AKP, da ich aktuell aufgrund mangelhafter Antennenleistung eine neue Heckscheibe bekomme.
Beinhaltet das AKP auch eine veränderte Heckscheibe ?
Also beim Kombi ist es ab der C-Säule auch das normale Glas.
