  4. US Cars
  5. Muß ABS-Steuergerät angelernt werden???
wenn mal wieder ein ABS-Steuergerät für mein Auto verfügbar ist, werde ich zuschlagen - ABER:
als ich heute meine alten Rechnungen nachgesehen habe, mußte ich feststellen, daß beim Wechsel 2006 auf der Rechnung steht: "ABS-Steuergerät justieren" -> bedeutet das, daß ein ABS-Steuergerät angelernt werden muß???
Danke für fachkundige Tips von Fachleuten!
9 Antworten
Und noch allgemeine Info:
ABS Description and Operation
FIGURE Left Side Frame Rail - w/o JL4(c)
(1) Electronic Brake Control Module (EBCM)
(2) Electronic Brake Control Module (EBCM) Electrical Connector - C1
(3) Electronic Brake Control Module (EBCM) Electrical Connector - C2
(4) Frame
FIGURE BPMV Hydraulic Flow(c)
(1) Master Cylinder
(2) Master Cylinder Reservoir
(3) Pump
(4) Brake Pressure Modulator Valve (BPMV)
(5) Damper
(6) Rear Isolation Valve
(7) Accumulator
(8) Rear Dump Valve
(9) Right Rear Brake
(10) Left Rear Brake
(11) Left Front Isolation Valve
(12) Left Front Dump Valve
(13) Left Front Brake
(14) Accumulator
(15) Right Front Brake
(16) Right Front Dump Valve
(17) Right Front Isolation Valve
(18) Damper
This vehicle is equipped with one of the following antilock braking systems.
• EBC325
• EBC325S (w/NW7)
The vehicle is equipped with the following braking enhancement systems.
• Antilock Brake System (ABS)
• Dynamic Rear Proportioning (DRP)
• Traction Control System (TCS) (w/NW7)
The following components are involved in the operation of the above systems.
• Electronic brake control module (EBCM) - The EBCM controls the system functions and detects failures. The EBCM contains the following components.
- System relay - The system relay is internal to the EBCM. The system relay is energized when the ignition is ON. The system relay supplies battery positive voltage to the solenoid valves and to the pump motor. This voltage is referred to as system voltage.
- Solenoids - The solenoids are commanded ON and OFF by the EBCM to operate the appropriate valves in the brake pressure modulator valve (BPMV).
• Brake pressure modulator valve (BPMV) - The BPMV uses a 3-circuit configuration to control the left front wheel, the right front wheel, and the combined rear wheels. The BPMV directs fluid to the left front and right front wheels independently. The BPMV directs fluid to the two rear wheels on a single hydraulic circuit. The BPMV contains the following components.
- Pump motor
- Three isolation valves
- Three dump valves
- A front low-pressure accumulator
- A rear low-pressure accumulator
• Wheel speed sensors (WSS) - As the front wheels spin, toothed rings located at each wheel hub interrupt magnetic fields in the wheel speed sensors. This causes each wheel speed sensor to generate an AC signal. The EBCM uses these AC signals to calculate the wheel speed. The wheel speed sensors are serviceable only as part of the wheel hub and bearing assemblies. Any imperfections in the toothed ring, such as a missing or damaged tooth, can cause an inaccurate WSS signal.
• Vehicle speed sensor (VSS) - The input signal for rear wheel speed originates at the VSS. The powertrain control module (PCM) receives rear wheel speed input from the VSS and supplies this information to the EBCM.
• Traction control switch (w/NW7) - The TCS is manually disabled or enabled using the traction control switch. The TCS can be programmed to be automatically enabled or disabled when the ignition is turned ON. The factory default is for the TCS to be automatically enabled. Refer to Programming the Traction Control Automatic Engagement Feature.
Initialization Sequence
The EBCM performs one initialization test each ignition cycle. The initialization of the EBCM occurs when the following conditions are met:
  • The ignition is ON.
  • The bulb check has been completed.
  • Vehicle speed is greater than 6 km/h (4 mph).
The initialization sequence briefly cycles each solenoid and the pump motor to verify proper operation of the components. The EBCM sets one or more DTCs in accordance with any malfunction that is detected.
The EBCM defines a drive cycle as the completion of the initialization sequence.
When wheel slip is detected during a brake application, the ABS enters antilock mode. During antilock braking, hydraulic pressure in the individual wheel circuits is controlled to prevent any wheel from slipping. A separate hydraulic line and specific solenoid valves are provided for each wheel. The ABS can decrease, hold, or increase hydraulic pressure to each wheel brake. The ABS cannot, however, increase hydraulic pressure above the amount which is transmitted by the master cylinder during braking.
During antilock braking, a series of rapid pulsations is felt in the brake pedal. These pulsations are caused by the rapid changes in position of the individual solenoid valves as the EBCM responds to wheel speed sensor inputs and attempts to prevent wheel slip. These pedal pulsations are present only during antilock braking and stop when normal braking is resumed or when the vehicle comes to a stop. A ticking or popping noise may also be heard as the solenoid valves cycle rapidly. During antilock braking on dry pavement, intermittent chirping noises may be heard as the tires approach slipping. These noises and pedal pulsations are considered normal during antilock operation.
Vehicles equipped with ABS may be stopped by applying normal force to the brake pedal. Brake pedal operation during normal braking is no different than that of previous non-ABS systems. Maintaining a constant force on the brake pedal provides the shortest stopping distance while maintaining vehicle stability.
Pressure Hold
The EBCM closes the isolation valve and keeps the dump valve closed in order to isolate the slipping wheel when wheel slip occurs. This holds the pressure steady on the brake so that the hydraulic pressure does not increase or decrease.
Pressure Decrease
If a pressure hold does not correct the wheel slip condition, a pressure decrease occurs. The EBCM decreases the pressure to individual wheels during deceleration when wheel slip occurs. The isolation valve is closed and the dump valve is opened. The excess fluid is stored in the accumulator until the pump can return the fluid to the master cylinder or fluid reservoir.
Pressure Increase
After the wheel slip is corrected, a pressure increase occurs. The EBCM increases the pressure to individual wheels during deceleration in order to reduce the speed of the wheel. The isolation valve is opened and the dump valve is closed. The increased pressure is delivered from the master cylinder.
The dynamic rear proportioning (DRP) is a control system that replaces the hydraulic proportioning function of the mechanical proportioning valve in the base brake system. The DRP control system is part of the operation software in the EBCM. The DRP uses active control with existing ABS in order to regulate the vehicle's rear brake pressure.
The red brake warning indicator is illuminated when the dynamic rear proportioning function is disabled.
When drive wheel slip is noted while the brake is not applied, the EBCM will enter traction control mode.
The EBCM uses a 5-volt pulse-width modulated (PWM) signal to request the PCM to reduce the amount of torque to the drive wheels. The PCM reduces torque to the drive wheels by retarding spark timing and by commanding the throttle actuator control. The PCM uses a 5-volt PWM signal in order to report to the EBCM the amount of torque delivered to the drive wheels.
Brake Warning Indicator
The instrument panel cluster (IPC) illuminates the brake warning indicator when the following occurs:
  • The body control module (BCM) detects that the park brake is engaged. The IPC receives a class 2 message from the BCM requesting illumination.
  • The EBCM detects a low brake fluid condition and sends a class 2 message to the IPC.
  • The IPC performs the bulb check.
  • An ABS-disabling malfunction also disables dynamic rear proportioning (DRP).
ABS Indicator
The IPC illuminates the ABS indicator when the following occurs:
  • The electronic brake control module (EBCM) detects an ABS-disabling malfunction. The IPC receives a class 2 message from the EBCM requesting illumination.
  • The IPC detects a loss of class 2 communications with the EBCM.
Traction Control Indicators (w/NW7)
LOW TRACTION
The low traction indicator is part of the traction control switch. The EBCM applies ground to the traction control active signal circuit in order to illuminate the low traction indicator during a traction control event.
TRACTION OFF
The traction off indicator, which is part of the traction control switch, turns OFF when ground is applied to the service traction control signal circuit. The EBCM illuminates the traction off indicator if any of the following conditions are present.
  • The EBCM inhibits the traction control system.
  • The driver manually disables the traction control system by pressing the traction control switch.
  • The automatic transmission shift lever is in the low (1) position.
The EBCM inhibits the traction control system when a TCS-disabling malfunction occurs, or when the automatic engagement feature is programmed to disable the TCS when the ignition is turned ON. Refer to Programming the Traction Control Automatic Engagement Feature.
The automatic engagement feature may be programmed so that the traction control system activates or does not activate automatically at the start of each ignition cycle. In order to change the status of the automatic engagement feature, perform the following procedure:
Important
Failure to follow the correct procedure may cause DTC C0283 to set in EBCM memory.
  1. Park the vehicle and apply the parking brake.
  2. Unlock the ignition and shift the transmission into NEUTRAL (N).
  3. Turn the ignition ON, engine OFF.
  4. Press and hold the brake pedal and the accelerator pedal.
  5. Press and hold the traction assist switch for 5 seconds.
  6. Release the brake and accelerator pedals and the traction control switch.
  7. Turn the ignition OFF.
kannst mir grad nochmal sagen um welches Modell und Modelljahr es sich genau handelt?
Dann kann ich dir konkretere Infos vllt geben. Aber so aus dem Bauch raus, JEIN, es muss schon eingepflegt werden damit PCM und BCM damit zurande kommen und wissen was Sache ist.
Das Steuergerät an sich wird allerdings sicher auch noch eine kurze Anlernphase haben, ggf. wegen verschiedenen Raddurchmessern etc.
Beispiel, Traktionskontrolle im Alero muss auch für neue Reifen bzw anderen Luftdruck angelernt werden, was allerdings während dem normalen fahren des Kunden passiert, der Mechaniker (Kunde) aktiviert nur den Prozess.
Mein Suburban von 2001
Folgendes bezieht sich jetzt nicht speziell auf dein Auto, aber ich habe mal in einem Haynes gelesen, dass das betreffende ABS-Modul (Hydraulikventilblock) beim Entlüften mit einem Diagnosetester durchgeschaltet werden muss, wenn Luft eingetreten ist. Sonst wird es nicht ausreichend entlüftet.
Korrekt. Das entlüften des Hydraulikblocks is ne Arbeit mit dem Tester. Aber wenn ich mich richtig erinnere geht's hier wirklich um das Steuergerät.
Wärst noch so nett und sagst mir das genaue Modell und Motor, das macht das suchen einfacher
Siehe den aller ersten und den letzten Punkt hier:
Electronic Brake Control Module Replacement
Removal Procedure
Important
After installation, calibrate the new EBCM to the tire size that is appropriate to the vehicle.
Warning! Unless directed otherwise, the ignition and start switch must be in the OFF or LOCK position, and all electrical loads must be OFF before servicing any electrical component. Disconnect the negative battery cable to prevent an electrical spark should a tool or equipment come in contact with an exposed electrical terminal. Failure to follow these precautions may result in personal injury and/or damage to the vehicle or its components.
Disconnect the negative battery cable.
Raise and suitably support the vehicle. Refer to Lifting and Jacking the Vehicle in General Information.
Bild 1
Important
The area around the EHCU MUST be free from loose dirt to prevent contamination of disassembled ABS components.
Thoroughly wash all contaminants from around the EHCU (1).
Disconnect the electrical connectors from the EBCM.
Loosen or remove the bolts (4) securing the EHCU mounting bracket (3) to the frame rail (5).
Bild 2
Gently move the EHCU down enough to remove the mounting screws that fasten the EBCM (2) to the BPMV (1).
Remove the EBCM (2) from the BPMV (1). Removal may require a light amount of force.
Important
Do not use a tool to pry the EBCM or the BPMV. Excessive force will damage the EBCM.
Clean the BPMV to EBCM mounting surfaces with a clean cloth.
Installation Procedure
Important
• Do not reuse the old mounting screws. Always install new mounting screws with the new EBCM.
• Do not use RTV or any other type of sealant on the EBCM gasket or mating surfaces.
Install the EBCM (2) on to the BPMV (1).
Caution!
Use the correct fastener in the correct location. Replacement fasteners must be the correct part number for that application. Fasteners requiring replacement or fasteners requiring the use of thread locking compound or sealant are identified in the service procedure. Do not use paints, lubricants, or corrosion inhibitors on fasteners or fastener joint surfaces unless specified. These coatings affect fastener torque and joint clamping force and may damage the fastener. Use the correct tightening sequence and specifications when installing fasteners in order to avoid damage to parts and systems.
Install the new screws in the EBCM (2).
Tighten
Tighten the screws to 5 N·m (39 lb in) in an X-pattern.
Install or tighten the EHCU bracket mounting bolts (4).
Tighten
  1. Tighten the EHCU bracket mounting bolts to 25 N·m (18 lb ft).
  2. Connect the electrical connectors to the EBCM.
  3. Lower the vehicle.
  4. Connect the negative battery cable.
  5. Revise the tire calibration using the Scan Tool Tire Size Calibration function.
  6. Return to Diagnostic Starting Point - Antilock Brake System .
(4) Frame
(1) Master Cylinder
(3) Pump
(5) Damper
(7) Accumulator
(8) Rear Dump Valve
(14) Accumulator
(18) Damper
• EBC325
• EBC325S (w/NW7)
- Pump motor
- Three dump valves
Pressure Hold
Pressure Decrease
Pressure Increase
ABS Indicator
LOW TRACTION
TRACTION OFF
Important
Ich danke Dir!
Gleich glüht der Translator bei Google.
Wenn du das schon übersetzt, könntest daraus en netten Text machen? Dann haben wir ne recht gute Beschreibung solcher Systeme für unser FAQ.
Danke
Übersetzung siehe Anhang
Hab´s als Word-Datei hochgeladen, vielleicht hat jemand, der besser englisch kann, Verbesserungsvorschläge.
