  4. Ford
  5. Focus & C-Max
  6. Focus Mk4
  7. Park radars
Park radars
Ford Focus Mk4
Anyone noticed that parking radars are not function always the same way.
Normally you can hear beeb beeb beeb... from that corner (speaker) of the car what is close to obstacle but sometimes "beeb" sound is comming from the behind of steeringwheel or inside the dashboard and really bad sound quality?
If you turn off the car and let it be several minutes park radars are working as normal again.
6 Antworten
I noticed that and i think, this happens, when sync3 is not active, cause of the battery save mode.
It sounds really really bad.
I'm also surprised that nobody noticed.
@wo359 schrieb am 7. Januar 2019 um 13:27:19 Uhr:
Yes you are right. It happens often when car has being in garage 24h or so and if Reverse is selected immediately after car is started.
Software bug I presume.
Double post, sorry
I think it happens as soon as the Car is started and your Sync3 is not yet fully booted. Then it defaults to the Dashboard speaker instead using the HiFi System. I think it works as intended!
It happens also if when you open the electric Trunk while the Car is parked for a longer time. The opening Chime is played from the Dashboard instead the Hifi System.
@KimeHyde schrieb am 7. Januar 2019 um 18:45:14 Uhr:
If you start the Car and immediately, the Camera is started (if available) and Sync3 is booted in the Background...you can see this because the Camera Controls will not show immediately!
So, it's not a bug, it's a feature. 😉
The first time, i heard this terrible sound, the pre heater of my car was working for about 20 minutes.
I went in the car, and saw on the display of sync3 a message. Battery safe mode is active or something like that.
I started the car and heard this sound. The normal sound came back after a restart 15 minutes later.
