Passat B7 2012 2.0 TDI Dashboard replacement
Hi there!
Sorry typing in English.
I have a Passat Variant 2012 2.0 TDI which have a mph dashboard 3AA920870E. Can I replace this dashboard for 3AA920880A? This colored 880A supports TPMS system and Start Stop? As fair as I know is those are the features that this car has compared to conventional models.
This dashboard in miles annoys me haha.
Greeting from Ireland
André
4 Antworten
Hello
Are you sure you installed the 870E? Because this pn is for gasoline engines with natural gas and with km/h display.
The 880A would be for diesel with km/h display. That would be fine.
@Mirco2706 schrieb am 17. September 2021 um 16:00:46 Uhr:
Hello
Hi there,
Sorry I typo in error actually is final 970E. Same as this one
https://www.ebay.de/.../124648211798?...
Thanks for that
André
Hi guys!
I’ve installed the dashboard 880A, then come up this fault code on dashboard for parking brake at 53- module at vcds 03194. The soft coding is 0022167 should I try change it to 0021167? Anyone know the security code in order to change it? The ABS module is 801G.
Hi guys this is the auto scan!
I have a Passat Variant B7 2012 Sport 2.0 Tdi and today I replaced the black and white OEM dashboard 3AA920970E for 3AA920880A. Then come up the fault code 03194 on parking brake module 53, which is 801G.
Is that possible access the security code of module 53 and change it? Now it is coded as 022167, should I use 021167?
Monday,27,September,2021,13:27:00:33316
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 21.9.0.2 (x64)
Data version: 20210903 DS330.0
www.Ross-Tech.com
Dealer/Shop Name: Andre Luis Freitas
Workshop Code: 123 12345 012345
VIN: WVWZZZ3CZCE114440 License Plate: 12C16375
Mileage: 178470km-110896mi Repair Order: 27-Sep-21
Chassis Type: 3C-VW46 (7N0)
Scan: 01 03 08 09 15 16 17 19 25 2E 37 42 44 46 4F 52 53 55 56 61
62 65 72
VIN: WVWZZZ3CZCE114440 Mileage: 178470km-110896miles
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
2E-Media Player 3 -- Status: OK 0000
37-Navigation -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: Malfunction 0010
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: OK 0000
61-Battery Regul. -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
65-Tire Pressure -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine (J623-CFGB) Labels:. 03L-906-018-CFF.clb
Part No SW: 03L 906 018 PT HW: 03L 907 309 AE
Component: R4 2.0l TDI H25 9980
Revision: 41H25--- Serial number: 00000000000000 CVN: 3F0B6B78
Coding: 00190012042501080000
Shop #: WSC 00423 210 00000
ASAM Dataset: EV_ECM20TDI01103L906018PT 003008
ROD: EV_ECM20TDI01103L906018PT.rod
VCID: 0B1271A1A2C774D124-805E
VINID: 9E69EAAAA0D3A9354104410400A4023285
No fault code found.
Readiness: 0 0 0 0 1
Address 03: ABS Brakes Labels: 3AA-614-109.clb
Part No SW: 3AA 614 109 AF HW: 3AA 614 109 AF
Component: J104 C2 450M V441 0023
Revision: --H07--- Serial number: 00000005100199
Coding: 0003001
Shop #: WSC 05311 000 00000
VCID: 71EE0349682B3E01BE-8024
Address 08: Auto HVAC (J255) Labels:| 5K0-907-044.clb
Part No SW: 3AA 907 044 B HW: 3AA 907 044 B
Component: Climatronic H03 0101
Revision: 00001K01
Coding: 0014004803
Shop #: WSC 00015 115 00000
ASAM Dataset: EV_Climatronic A01010
ROD: EV_ClimaAutoBasis_VW46.rod
VCID: 2F6AC531769F68F1E8-807A
1 Fault Found:
9481988 - Air Quality Sensor
B10AF 04 [008] - Internal System Fault
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 3
Fault Frequency: 1
Reset counter: 105
Mileage: 178470 km
Date: 2021.09.27
Time: 00:16:24
Address 09: Cent. Elect. (J519) Labels:. 3AA-937-087.clb
Part No SW: 3AA 937 087 H HW: 3AA 937 087 H
Component: BCM PQ47 H+ 421 0464
Revision: BC421001
Coding: 000800000000000000180080140029F423D50088626D8160E480C7240041
Shop #: WSC 12345 123 12345
VCID: 3F8A9571AEFF987178-806A
Subsystem 1 - Part No: 3AC 955 119 Labels: 1KX-955-119.CLB
Component: Wischer 28111 26 0612
Coding: 00B795
Subsystem 2 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
Component: RLS 071211 05 54 0403
Coding: 0730ED
Address 15: Airbags Labels: 5N0-959-655.lbl
Part No SW: 5N0 959 655 R HW: 5N0 959 655 R
Component: J234__102 VW10 HI 1918
Revision: 23016000 Serial number: 003K0PRCTGY.
Coding: 0012338
VCID: 4C90B2BD2F4933E9ED-8018
Subsystem 1 - Serial number: 6332MTS671433251
Subsystem 2 - Serial number: 6342MTS695893261
Subsystem 3 - Serial number: 6351HTS6PNHA0AKJ
Subsystem 4 - Serial number: 6361HTS6D7L50AKJ
Subsystem 5 - Serial number: 00000000000000000
Subsystem 6 - Serial number: 00000000000000000
Address 16: Steering wheel (J527) Labels:| 3C0-953-569.clb
Part No SW: 3C9 953 501 BN HW: 5K0 953 569 AB
Component: LENKS.MODUL 014 0140
Revision: FF010040 Serial number: 20111208200195
Coding: 1182250000
ASAM Dataset: EV_VW360SteerWheelUDS A03004
ROD: EV_VW360SteerWheelUDS.rod
VCID: 76E43055C94519396B-8022
Multifunction steering wheel control module:
Subsystem 1 - Part No SW: 3C8 959 537 D HW: 3C8 959 537 D Labels: 3C8-959-537.CLB
Component: E221__MFL-TK6 H06 0022
Coding: E20000
Address 17: Instruments (J285) Labels:| 3C8-920-xxx-17.clb-SRI1
Part No SW: 3AA 920 880 A HW: 3AA 920 880 A
Component: KOMBI H02 0206
Coding: 160F01
Shop #: WSC 00028 028 00206
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04089
ROD: EV_Kombi_UDS_VDD_RM09_004_VW46.rod
VCID: 316EC34960AB7E01FE-8064
Address 19: CAN Gateway (J533) Labels:. 7N0-907-530-V2.clb
Part No SW: 7N0 907 530 Q HW: 1K0 907 951
Component: J533 Gateway H41 1623
Revision: H41 Serial number: 191111F1002821
Coding: 462007
Shop #: WSC 05314 000 00000
VCID: 3E74E875A9F5917973-806A
Address 25: Immobilizer Labels: 3C0-959-433-25.clb
Part No SW: 3AA 959 433 HW: 3AA 959 433
Component: IMMO 043 0400
Revision: 00043000 Serial number: VWZCZ000000000
Shop #: WSC 24641 002 1048576
VCID: 76E43055014519396B-8022
Subsystem 1 - Part No: 3C0 905 861 J
Component: ELV 029 0380
3C0905861J ELV 029 0380
Address 2E: Media Player 3 (J650) Labels:. 5N0-035-342.lbl
Part No SW: 5N0 035 342 E HW: 5N0 035 342 E
Component: SG EXT.PLAYER H13 0240
Revision: A1001003 Serial number: 7661443547
Coding: 020000
VCID: 295E2B29407B06C136-807C
Address 37: Navigation (J794) Labels:| 1K0-035-27x-37.clb
Part No SW: 3C0 035 279 G HW: 3C0 035 279 G
Component: RNS315-EU H35 0263
Serial number: VWZAZ2L3887201
Coding: 040004010400110000019002
ASAM Dataset: EV_RNS315EUV2UDS A01004
ROD: EV_RNS315EUV2UDS.rod
VCID: 275A2D115E6F30B120-8072
Data carrier:
Subsystem 1 - Part No: 3AA 919 866
Component: EUR_W_0038 0038
1 Fault Found:
1048642 - Internal Control Module Memory Check Sum Error
B2000 42 [009] - General Memory Failure
[New feature! Extended UDS fault detail is only supported by current gen. interfaces]
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Mileage: 150095 km
Date: 2021.03.16
Time: 16:27:15
Address 42: Door Elect, Driver (J386) Labels:| 3C0-959-70X-GEN4.clb
Part No SW: 3AA 959 701 A HW: 3C0 959 793 C
Component: TUER-SG FT 002 0534
Revision: 12110009 Serial number: 0004003913
Coding: 0202B7
Shop #: WSC 05311 115 00000
ASAM Dataset: EV_TSGFPQ35BRFVW46X A04001
ROD: EV_TSGFPQ35BRFVW46X_VW32.rod
VCID: 3566F75994C35221A2-8060
Slave Driver:
Subsystem 1 - Part No SW: 3C0 959 704 HW: 3C0 959 794 Labels: 1K0-959-70X-GEN4.CLB
Component: J389__TSG-HR 004 0407
Serial number: 00000002604237
Coding: 000290
Address 44: Steering Assist Labels: 1K0-909-14x-GEN3.clb
Part No: 1K0 909 144 N
Component: EPS_ZFLS Kl. 196 3301
Revision: 00H22000
Shop #: WSC 02069 000 90108
VCID: 3566F7595CC35221A2-8060
Address 46: Central Conv. Labels:. 3C0-959-433-46.clb
Component: KSG PQ47 ELV 043 0634
Coding: 1191020052834E763402941D7C085FCE105C01
Subsystem 1 - Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H05 1501
Subsystem 2 - Part No: 3C0 951 171 C
Component: Neigungssensor 004 0611
Subsystem 3 - Part No: 3C0 951 171 C
Component: Innenraumueberw.004 0611
Address 4F: Centr. Electr. II (J520) Labels:. 1K0-907-532.clb
Part No SW: 7N0 907 532 HW: 1K0 907 951
Component: EZE_2 H41 1623
Coding: 00000008
VCID: 6FEA0531BE1F28F1A8-803A
Subsystem 1 - Part No SW: 3AA 919 204 A HW: 3AA 919 204 A
Component: Analoguhr 004 0003
Address 52: Door Elect, Pass. (J387) Labels:| 3C0-959-70X-GEN4.clb
Part No SW: 3AA 959 702 A HW: 3C0 959 792 C
Component: TUER-SG BT 002 0534
Revision: 14110009 Serial number: 0004009434
Coding: 0202B6
ASAM Dataset: EV_TSGBPQ35BRFVW46X A04001
ROD: EV_TSGBPQ35BRFVW46X_VW32.rod
VCID: 3664F05589C55939AB-8062
Slave Passenger:
Subsystem 1 - Part No SW: 3C0 959 703 HW: 3C0 959 795 Labels: 1K0-959-70X-GEN4.CLB
Component: J388__TSG-HL 004 0407
Serial number: 00000002617718
Coding: 000290
Address 53: Parking Brake Labels: 3AA-907-801.clb
Part No SW: 3AA 907 801 G HW: 3AA 907 801 G
Component: J540 EPB4 VW-64783 0009
Revision: H19 Serial number: 00000000490336
Coding: 0022167
1 Fault Found:
03194 - Incompatible Interface
000 - -
Freeze Frame:
Fault Status: 01110000
Fault Priority: 2
Fault Frequency: 4
Reset counter: 65
Time Indication: 0
Date: 2016.02.18
Time: 00:00:49
Freeze Frame:
Voltage: 11.80 V
Count: 95
Speed: 0.0 km/h
Hex Value: 0x1263
Hex Value: 0x0001
Hex Value: 0x1010
Address 55: Headlight Range (J745) Labels:. 5M0-907-357-V3.clb
Part No SW: 5M0 907 357 F HW: 7L6 907 357 C
Component: AFS-ECU H04 0111
Revision: -------- Serial number: --------------
Coding: 029600000B000200
ASAM Dataset: EV_HeadlRegulVWAFSPt 002016
ROD: EV_HeadlRegulVWAFSPt_VW46.rod
VCID: 377AFD518ECFA031B0-8062
Subsystem 1 - Part No SW: 3D0 941 329 HW: 3D0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo links H04 0011
Coding: 230000
Subsystem 2 - Part No SW: 3D0 941 329 HW: 3D0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo rechts H04 0011
Coding: 230000
Address 61: Battery Regul. (J840) Labels:. 1K0-907-534.clb
Part No SW: 7N0 907 534 HW: 1K0 907 951
Component: Batt.regelung H41 1623
Coding: 030F185A
VCID: 71EE0349A82B3E01BE-8024
Subsystem 1 - Part No SW: 1K0 915 181 H HW: 1K0 915 181 A
Component: J367-BDM H07 0180
Serial number: 00000000008900261377
Address 65: Tire Pressure (J502) Labels: 3AA-907-273.clb
Part No SW: 3AA 907 273 D HW: 3AA 907 273 D
Component: RDKBERU30 H09 0010
Serial number: 10000000082517
ASAM Dataset: EV_RDKBERU30 003012
ROD: EV_RDKBERU30_003.rod
End-------------------------(Elapsed Time: 03:46)--------------------------
