RDK / Tire Pressure from B7 in B6
Retrofitted this and the wheel sensors are in place, but I have this error:
Google translate: Diese nachgerüstet und die Radsensoren sind zwar vorhanden, aber ich habe diese Fehlermeldung:
Address 65: Tire Pressure Labels: 3AA-907-273.clb
Control Module Part Number: 3AA 907 273 D HW: 3AA 907 273 D
Component and/or Version: RDKBERU30 H09 0010
Software Coding:
Work Shop Code:
ASAM Dataset: EV_RDKBERU30 003012 (VW46)
VCID: 356B01EE94FC18898CD-8060
1 Fault Found:12652550 - invalid data record
B2005 00 [009] - -
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 3
Fault Frequency: 1
Reset counter: 0
Mileage: 0 km
Date: 2000.00.00
Time: 00:00:00
Some others parts in my car:
Address 03: ABS Brakes Labels: 3C0-614-109-C4.clb
Part No SW: 3C0 614 109 AF HW: 3C0 614 109 AF
Component: J104 C4 440 V2 0015
Revision: --025--- Serial number: 00000796030080
Coding: 0002305
Shop #: WSC 05311 000 00000
VCID: 62C18AB2BDF2DF0EED3-8037No fault code found.
Address 09: Cent. Elect. Labels: 3AA-937-087.clb
Control Module Part Number: 3AA 937 087 J HW: 3AA 937 087 J
Component and/or Version: BCM PQ47 H++ 420 0465
Software Coding: 00080000000000000098008820000ABE65746888637D8522648008200000
Work Shop Code: WSC 00070 123 104857
VCID: 4183653ED834A429205-8014No fault code found.
Address 17: Instruments (J285) Labels: 3C8-920-xxx-17.clb
Part No SW: 3C8 920 880 QX HW: 3C8 920 880 QX
Component: KOMBI H04 0611
Serial number: 00000000000000
Coding: 161E01
Shop #: WSC 00001 123 12345
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04723
ROD: EV_Kombi_UDS_VDD_RM09_VW21.rod
VCID: 92211A7245D26F8EBD3-80C7No fault code found.
Address 19: CAN Gateway (J533) Labels: 7N0-907-530-V2.clb
Part No SW: 7N0 907 530 AE HW: 7N0 907 530 AE
Component: J533 Gateway H46 1633
Revision: H46 Serial number: 051012F1000820
Coding: 462006
Shop #: WSC 05314 123 12345
VCID: 73EFFFF6D2084686965-8026No fault code found.
I have VCDS / ODIS / ODIS Engineering available
diskoboy
12 Antworten
Dein Datensatz ist nicht vorhanden oder kaputt
@diskoboy schrieb am 4. Dezember 2014 um 23:35:12 Uhr:
Hi,Retrofitted this and the wheel sensors are in place, but I have this error:
Some others parts in my car:Zitat:
Software Coding:
Work Shop Code:
B2005 00 [009] - -
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 0
Mileage: 0 km
Date: 2000.00.00
Time: 00:00:00
I have VCDS / ODIS / ODIS Engineering availableZitat:
Coding: 0002305
Coding: 161E01
Coding: 462006
diskoboy
B7 tire pressure control explicitly needs the extended can bus. On the other side, there are 7N0 gateway modules that don't support extended can. As far as I remember 7N0 AE is one of that modules. In other words you have to change your gateway to another one, e.g. 7N0 AN.
@wk205 schrieb am 4. Dezember 2014 um 23:58:32 Uhr:
B7 tire pressure control explicitly needs the extended can bus. On the other side, there are 7N0 gateway modules that don't support extended can. As far as I remember 7N0 AE is one of that modules. In other words you have to change your gateway to another one, e.g. 7N0 AN.Zitat:
diskoboy
Edit: bronken is right. Without extended can you would get another error code, no communication to rdk module.
Aber du hast recht. Welches war denn das ohne Ex CAN? Das nach Flashen zum AN auch kein AN wurde... War das nicht AE? Oder AK?
Will the 7N0 AN also work with this ? I'm having the same "invalid data record" here...
Address A5: Frt Sens. Drv. Assist Labels: 3AA-980-654.clb
Control Module Part Number: 3AA 980 654 D HW: 3AA 980 654 A
Component and/or Version: MFK_Gen1 H08 0300
Software Coding: 010101000102020D0201040001010000
Work Shop Code: WSC 12345 123 12345
ASAM Dataset: EV_47X 001639 (VW46)
VCID: 39730DDEB8E4FCE9685-806C
3 Faults Found:4390912 - Databus
U1123 00 [008] - Received Error Message
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 137
Mileage: 156853 km
Date: 2009.14.30
Time: 08:52:075832704 - Incorrect Basic Setting
B2011 00 [009] - -
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 85
Mileage: 156443 km
Date: 2009.14.24
Time: 15:35:326553600 - invalid data record
B2005 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 85
Mileage: 156443 km
Date: 2009.14.24
Time: 15:35:28
The camera is not calibrated yet!! ... My "Side Assist" (using extended can) is working perfect, so the GW must have a working ex-can-bus...
@bronken schrieb am 5. Dezember 2014 um 00:03:38 Uhr:
Ich meine AE. Aber die Fehlermeldung sieht aus als ob irgendeine Kommunikation zum RDK Stg stattfindet. Und sein SWA geht ja wohl.
Die Kamera brauchst gar nicht Kalibrieren, die hat auch keinen Datensatz. Das muss mal zuerst.
@wk205 schrieb am 5. Dezember 2014 um 00:17:02 Uhr:
When you say " SWA " ? Software / Hardware - what do you mean? Is my cluster
3C8 920 880 QXokay for RDK / Front Kamera?
SWA=SpurWechselAssistent aka SideAssist. And yes, your cluster should be new enough to match the features.
How about indirect-TPMS? (using the ABS sensors) - should it be disabled in [03-ABS]?
In [46-Komfort / 3AA 959 799 E], it should be enabled. Current coding: 18910A0051434E7630069515300A8F0B605C00032437BC
Is there any coding in [09-BCM] regarding RDK?
Here is says I need to flash the firmware:
https://vcp-forum.de/viewtopic.php?f=8&t=342&p=3295#p3295
Borrowed a USED RFK-StG:
Control Module Part Number: 3AA 907 273 B HW: 3AA 907 273
Component and/or Version: RDKBERU30 H05 0008
Software Coding:
Work Shop Code:
ASAM Dataset: EV_RDKBERU30 003010 (VW46)
VCID: 336EAB459A6700B9A29-8066
No problems at all. It shows up in the cluster without any coding. Sensors are in place and it works.
The " D " (see earlier posts) is brand new, and perhaps that could cause the problem?
Later this week I'll get VAG CAN Pro - hopefully then I can upload another flash file it to see if that solves the error.
I'm still having problems with the Front Camera - bought a used one on ebay, but it comes with the exactly same errors and when connected it says it's not coded (suspects that it's brand new, but it has some scratches and marks so perhaps it's really used...
Is the coding deleted when moved to a new car?
Die "Invalid Data Record" im RDK schon gelost? Habe das gleiche Problem mit einem F Version.
