  4. Mercedes
  5. C-Klasse
  6. W205
  7. Strange problem when braking...
Mercedes C-Klasse W205
Themenstarteram 1. September 2024 um 14:40
Hello to all!
I have strange problem when braking at speed above 50 km/h.
Sound I get is like some metal is grinding. Feels like in position of drive shaft.
On speed between 45 to 60 I can hear like bad bearing high humming noise. It is not very loud but I can hear it.
For input recently changed all 4 wheele bearings and all brakes are almost new.
Problem I first heard when I start to brake going downhill.
Any help and suggestion or someone had same issue and reparied it.
Thank you!
3 Antworten
Hello,
how long ago was the change ? was original mercedes trile used ?
maybe give some details about the exact vehicle
Themenstarteram 3. September 2024 um 16:18
@C4H4N schrieb am 3. September 2024 um 12:03:10 Uhr:
Hello,
I am positive that sound is in drive shaft area but not sure if center bearing bad or something else. :confused:
Themenstarteram 20. November 2024 um 17:03
Solved
I had loosened nut on bolt on left rear arm below level sensor
