Suche adaptations vergleich 5Q0 907 530 AC HW: 5Q0 907 530 F
Ich suche eine adaptations map auf Gateway 5Q0 907 530 AC HW: 5Q0 907 530 F.
wer kann mir helfen
11 Antworten
Is an adp map of mine any good to you?
Code:
Address 19: CAN Gateway (J533) Labels: 5Q0-907-530-V1.clb
Part No SW: 5Q0 907 530 M HW: 5Q0 907 530 M
Component: GW MQB High 212 2147
Revision: -------- Serial number:
Coding: 030100040B087300EF00065E880F00010001000000000000000000000000
Shop #: WSC 00028 028 00212
ASAM Dataset: EV_GatewConti 009011
ROD: EV_GatewConti.rod
VCID: 3B75335AB25CEBE67E-806E
Alternator:
Multifunction unit control module:
Subsystem 2 - Part No SW: 5G0 959 442 K HW: 5G0 959 442 K
Component: E221__MFL-DC1 H15 0038
Serial number:
Coding: 2CFFFF
Battery Monitoring Control Module:
Subsystem 3 - Part No SW: 5Q0 915 181 C HW: 5Q0 915 181 C
Component: J367-BDMHella H03 8042
Serial number:
No fault code found.
I can do you an ADP map of mine [tomorrow] which has all adaptation values.... if it helps you?
Thanks,
I want to look what kind of setting actief.
If i connect my old gateway again to look will this give errors like component protection again.
Sorry I was quite busy today workwise. I'll try and do a map for you tomorrow when I have 15 minutes in the car.
No Problem i want to get the fault message out.
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
5F-Information Electr. -- Status: Malfunction 0010
Address 01: Engine (J623-CJZB) Labels: 04E-907-309-V1.clb
Part No SW: 04E 906 016 E HW: 04E 907 309 A
Component: 1.2l R4 TSI H08 7695
Revision: WAH08---
Coding: 01110032232415082000
Shop #: WSC 51969 000 1048576
ASAM Dataset: EV_ECM12TFS01104E906016E 001011
ROD: EV_ECM12TFS01104E906016H.rod
VCID: 245BFC2B7EDB06A25B085A5-8070
Readiness: 0100 0001
Address 03: ABS Brakes (J104) Labels: 5Q0-907-379-IPB-V1.clb
Part No SW: 5Q0 907 379 AC HW: 5Q0 907 379 D
Component: ESC H75 0437
Revision: 00000000 Serial number:
Coding: 01FA6AA120212A6C0377060401CB2580560454C06080A4F300 28F02AC0
Shop #: WSC 12345 123 123465
ASAM Dataset: EV_Brake1UDSContiMK100IPB 008020
ROD: EV_Brake1UDSContiMK100IPB_VW37.rod
VCID: 7DEDE94FBDF1976A7486B79-8028
Address 08: Auto HVAC (J255) Labels: 5G0-907-044.clb
Part No SW: 5G0 907 044 R HW: 5G0 907 044 R
Component: Climatronic H02 0503
Revision: 00001K06
Coding: 00020004200100011005000000101000
Shop #: WSC 00028 028 00024
ASAM Dataset: EV_ACClimaBHBVW37X 002017
ROD: EV_ACClimaBHBVW37X_SK37.rod
VCID: 367F3663D8478432F57C80D-8062
Address 09: Cent. Elect. (J519) Labels: 5Q0-937-08X-HV1.clb
Part No SW: 5Q0 937 084 AA HW: 5Q0 937 084 L
Component: BCM MQBAB H H14 0112
Serial number: 00011227800350
Coding: 00040846C2C102FB0BA44080B11C0708100A00000000000000 0000000000
ASAM Dataset: EV_BCMCONTI 011001
ROD: EV_BCMBOSCH_AU37.rod
VCID: 77E1FB679FCDBD3A2ECAF51-8022
Slave 1:
Subsystem 1 - Part No SW: 5G1 955 119 A HW: 5G1 955 119 A Labels: 5QX-955-119-V1.CLB
Component: WWS 120910 042 0551
Serial number: 120924160900
Coding: 0E4DD5
Slave 2:
Subsystem 2 - Part No SW: 5Q0 955 547 HW: 5Q0 955 547 Labels: 5Q0-955-547.CLB
Component: RLFS 024 0042
Serial number: Y12M09D26H11M47S40S4
Coding: 06A8DD
Subsystem 3 - Part No SW: 5Q0 951 172 HW: 5Q0 951 172
Component: Sensor, DWA 005 0313
Serial number: 000000000ZY1306406H5
Subsystem 4 - Part No SW: 5Q0 951 605 HW: 5Q0 951 605
Component: Sirene, DWA 004 0311
Serial number: 00000000000056969920
1 Fault Found:
197644 - Control Circuit for Fuel Tank Flap
B1263 01 [009] - Electrical Failure
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 4
Fault Frequency: 1
Reset counter: 190
Mileage: 45993 km
Date: 2016.05.20
Time: 23:07:13
Address 10: Park/Steer Assist (J791) Labels: 5Q0-919-298.clb
Part No SW: 5Q0 919 298 B HW: 5Q0 919 298
Component: PARKHILFE PLA H11 0033
Revision: -------- Serial number: 61131307100194
Coding: 0031161041
ASAM Dataset: EV_EPHVA2CAU3700000 003015
ROD: EV_EPHVA2CAU3700000_VW37.rod
VCID: 3E6F2E43F0774C722D0C78D-806A
Address 15: Airbags (J234) Labels: 5Q0-959-655.clb
Part No SW: 5Q0 959 655 C HW: 5Q0 959 655 C
Component: AirbagVW20 011 0361
Serial number: 003F5R00E6ZJ
Coding: 98CCC000000000005C0000CF004800000065
Shop #: WSC 00028 028 00057
ASAM Dataset: EV_AirbaVW20SMEVW37X 002126
ROD: EV_AirbaVW20SMEVW37X_AU37.rod
VCID: 409350BB8A833A825FE0165-8014
Crash sensor for side airbag; driver side:
Subsystem 1 - Part No SW: ----------- HW: 480 000 310 12
Component: SideSensor_Df 001 0887
Serial number: 35767000000E2845EB00
Coding: 2D2D2D
Crash sensor for side airbag; front passenger side:
Subsystem 2 - Part No SW: ----------- HW: 480 001 708 13
Component: SideSensor_Pf 001 0887
Serial number: 35867000000ED2CC6D0F
Coding: 2D2D2D
Crash sensor for side airbag; rear; driver side:
Subsystem 3 - Part No SW: ----------- HW: 480 400 910 12
Component: SideSensor_Dr 001 6149
Serial number: 3516502A90D19C31C0EK
Coding: 2D2D2D
Crash sensor for side airbag; rear; passenger side:
Subsystem 4 - Part No SW: ----------- HW: 480 400 910 12
Component: SideSensor_Pr 001 6149
Serial number: 3526502AD0CD5EB313CY
Coding: 2D2D2D
Crash sensor for front airbag; driver side:
Subsystem 5 - Part No SW: ----------- HW: 480 400 210 12
Component: FrontSensor_D 001 6149
Serial number: 3556502B30CD5EB4531M
Coding: 2D2D2D
Address 16: Steering wheel (J527) Labels: 5Q0-953-549.clb
Part No SW: 5Q0 953 507 AA HW: 5Q0 953 549
Component: Lenks. Modul 007 0070
Revision: -------- Serial number: 1510120003004H
Coding: 8400
Shop #: WSC 51454 001 1048576
ASAM Dataset: EV_SMLSKLOMQB 009001
ROD: EV_SMLSKLOMQB_SE37.rod
VCID: 75FDF16F85C1CF2A3CF6DF9-8020
Address 17: Instruments (J285) Labels: 5G0-920-XXX-17.clb
Part No SW: 5G0 920 871 HW: 5G0 920 871
Component: KOMBI 353 2200
Coding: 07A502002390000800086A00040000
ASAM Dataset: EV_DashBoardVDDMQBAB 008031
ROD: EV_DashBoardVDDMQBAB_AU37.rod
VCID: 67C1AB27CF6D2DBABE6AA51-8032
Part No SW: 5Q0 907 530 AC HW: 5Q0 907 530 F
Component: GW MQB High 128 1203
Revision: -------- Serial number: 0001839445
Coding: 030100042B086400EF000648080F0001000100000000000000 0000000000
Shop #: WSC 01357 011 00200
ASAM Dataset: EV_GatewLear 011020
ROD: EV_GatewLear.rod
VCID: 72F7CA73F4AFD81219143CD-8026
Alternator:
Subsystem 2 - Part No SW: 5G0 959 442 J HW: 5G0 959 442 J
Component: E221__MFL-DC1 H14 0035
Serial number: 23130000529820100291
Coding: 280000
Serial number: 5430458201
Address 42: Door Elect, Driver (J386) Labels: 5QX-959-X93-42.clb
Part No SW: 5Q0 959 593 B HW: 5Q0 959 593 B
Component: TSG FS 020 0025
Serial number: 29051301100188
Coding: 001F0220D000020000001000
ASAM Dataset: EV_DCUDriveSideEWMAXKLO 006003
ROD: EV_DCUDriveSideEWMAXCONT_AU37.rod
Subsystem 1 - Part No SW: 5Q4 959 811 A HW: 5Q4 959 811 A
Component: Fond FHSG DRV 007 0002
Serial number: 00000000000000243883
Coding: 010000
Address 44: Steering Assist (J500) Labels: 5Q0-909-144.clb
Part No SW: 5Q0 909 144 L HW: 5Q0 909 144 L
Component: EPS_MQB_ZFLS 119 1021
Coding: 03
ASAM Dataset: EV_SteerAssisMQB 008022
ROD: EV_SteerAssisMQB.rod
VCID: 3D6D294FFD71576A3406779-8068
Address 52: Door Elect, Pass. (J387) Labels: 5QX-959-X92-52.clb
Part No SW: 5Q0 959 592 B HW: 5Q0 959 592 B
Component: TSG BFS 020 0023
Serial number: 06031302090088
Coding: 001F0020DE00020000801000
ASAM Dataset: EV_DCUPasseSideEWMAXKLO 006003
ROD: EV_DCUPasseSideEWMAXCONT_AU37.rod
VCID: 3F915347F77D457A261A6D1-806A
Subsystem 1 - Part No SW: 5Q4 959 812 A HW: 5Q4 959 812 A
Component: Fond FHSG PSG 007 0002
Serial number: 00000000000000247280
Coding: 090000
Address 5F: Information Electr. (J794) Labels: None
Part No SW: 5G0 035 846 A HW: 5G0 035 846
Component: MU-S-N-ER 038 0421
Serial number: V1F01510120522
Coding: 02730001FF00000011110001000800001F0100940100010045
Shop #: WSC 12345 666 54321
ASAM Dataset: EV_MUStd4CPASE 002039
ROD: EV_MUStd4CPASE_SK37.rod
VCID: 2741EB270FEDEDBA7EEA651-8072
Media Player Position 1:
Subsystem 1 - Part No SW: 5G0 919 605 D HW: 5G0 919 605 D
Component: ABT_Std_Nav H51 0022
Serial number: VWZ8Z9NJ902C5F
Engine Control Module 2:
Subsystem 2 - Part No SW: 5G0 919 866 AC HW: -----------
Component: ECE 2016 --- 0054
Serial number: --------------------
1 Fault Found:
7203 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 190
Mileage: 45993 km
Date: 2016.05.21
Time: 10:54:40
see attached...
Hello all,
I have compare the gateway but this is a version what dit not have the same adaptations.
Because i have more options, so compare with what you have is the same.
only the extra adaptions i cant compare.
Today i have switch the gateway back and this is olso working.
The problem with this gateway is the mechanic have flas this with vcp to a newer version.
So on the 19 gateway i have a eroor that says that the gateway has flashed so he told me that this Always be on the gateway when you read this with vcds.
Is this treu and can this be cleared with a nother option.
so one o the other have a error.
one in 5F and the other in 19.
19 with error midrage gateway.
5F with high error.
i hope that the error can dig out.
and here i need help
