Von Navi 600 Navi 900 machen kostenlos
Habe gelesen on
http://www.insignia-enthusiast.org/forums/index.php?showtopic=8094
Muss erst regristrieren hier um zu lesen
Es soll möglich sein mit software dass navi 600 ein 900 navi zu machen : hier die text :
You need:-
* An empty USB memory stick (formatted to FAT32)
* A blank CDR
It will wipe radio presets, address book, and saved destinations.
1. Download these two files:
http://opel-club.ru/files/navi_600_900_rus_fix.rar
http://yadi.sk/d/lmhsKgwO4crXM
2. Burn the ISO file to the CDR and copy the contents of the ZIP file to the root directory of the memory stick.
3. Go out to the car and switch on the navi system (ignition on or off doesn't matter), remove the SD card, and insert the memory stick. Follow instructions - it will fail at about 80%, this is expected.
4. Remove USB stick, insert CD, and switch unit off and on. This kicks you into the bootloader where it then proceeds to flash a load of stuff from the CD. Takes about eight minutes.
5. Reinsert SD card and let navigation initialise.
6. Reinsert memory stick and repeat installation - it'll work this time.
7. Give the system a chance to reboot a few times and it'll wake up to be a Navi 900.
Basically, the Navi 900 is set up to respond to voice commands (to choose radio station, for example) but our SD card is missing the voice files. So hitting the voice command button pops up a message saying that the language packs aren't installed. However, if you're on the phone screen, voice commands are routed to the bluetooth module and work normally.
Sie auch :
http://cruze-forum.de/viewtopic.php?f=14&t=3699
Navi 600 und Navi 900 : Hardware soll 100% identisch sein
Ich denke, Flashen ist immer ein Risiko
Aber viele habe es gemacht nach diese Foren
Jemand schon getan beim diesem forum
Grüßen aus Holland
Spricht man mal über die (sichere) Demontage von Airbags oder nutzen von OP-COM Clonen wird man fast geblockt, aber Threads über Illegale Software sind erlaubt?
Ich mein mir ist es egal, ich nutze auch viel illegales, aber da sollte die Moderation mal lngsam wissen was sie will.
Kauft euch den Mist und fertig...dann wundern sich noch alle warums Opel so schlecht geht.
341 Antworten
hmmm interessant. wäre wirklich interessant zu erfahren ob es jemand an nem deutschen astra schon gemacht hat.
Im Mokkaownersclub sind ja alle sichtlich angetan. Und wie du schreibst, scheints auch bei den Cruze Fahren zu funktionieren.
Ich frage mich nur ob das Update dann auf Dauer drauf bleibt (also auch nach Softwareupdates beim FOH). Ich denke mal eher nicht. Ist die Frage ob man dieses "Risiko" dann eingehen sollte. hmmm 😉
Ohne Mikro und Blauzahn, wie soll das gehen?
Und auf die 3D-Darstellung kann ich verzichten ...
Ich habe es gerade nach Anleitung Cruze Forum gemacht .....alles prima und 3d...
für die Sprachsteuerung fehlt wohl das 2 Micro!!! sonst geht alles
Gruß MK
Für das Handy die Sprachsteuerung geht natürlich auch noch aber nur im Phone Modus...
sonst kommt das Sprachmenü des jeweiligen Menüs Radio,Navi..usw.
wenn es der hersteller so leicht macht kann man es wohl empfehlen. 😁
Ist Frage was nach einen Update durch den FOH passiert? Weil der denkt ja ich habe das navi 600!
wie siehts dann mit der menüsprache aus? kann man weiterhin deutsch einstellen oder ist alles englisch?
Definiere "2. Mikrofon"....
So nach der Probefahrt alles i.o. und natürlich alles in deutsch.......
Und ich denke mal 2. Mikro weil er mich bei der Sprachsteuerung nicht hört nur bei der Handysteuerung!
Wozu ein zweites Mikrofon für ANDERE Sprachbefehle?
Wohl eher ein Fehler bei der Portierung...
Aber werde es auch testen am Wochenende
Das weiß ich auch nicht , jedenfalls reagiert das navi und Radio nicht auf meine Stimme vielleicht nuschle ich auch........ 😮) wäre super wenn jemand dafür eine Lösung findet
Voraussetzung für ein zweites Mikro dürfte wohl ein Erstes sein 😉 . Das gibt es aber nur bei einer vorhandenen FSE, oder täusche ich mich da ?
Also ich habe eine Bluetooth Freisprech(orginal)
Es könnte sein, daß bei dem Navi900 für die Sprachsteuerung ein extra Mikrofon verbaut ist und mit der Bluetooth-Freisprecheinrichtung der Telefonsteuerung nix zu tun hat. Das ist dann beim Navi600 natürlich nicht dabei. In dem Fall kann dann auch die Sprachsteuerung für's Navi nicht funktionieren.
Jemand , der Zugang zum EPC hat könnte da mal nachschauen.
